What Lies Beneath...
Discussion in 'Builds & Projects' started by DCS222, Jun 2, 2017.
  1. bogg
    bogg Senior Member
    Feb 21, 2016
    west sussex
    Or up norf
  2. DCS222
    DCS222 Guest
    Ok, bringing this thread back on track... I finished putting the bike together today. The only obvious issue was a slow, drip - drip, from the fuelcock/fuel line interface. I think the fuel line is a bit like Mick Jagger, does the job of keeping the motor going, but getting a bit old n' stiff! Again, I'll swap this out sometime, but a jubilee clip from me majik bog o' spares does a fine job of rectification!
    Just been out on a shake down ride to burn the grease off and find loose bolts... loved it! now its back in the garage awaiting the results of my single seat pondering!
  3. dilligaf
    Looking good mate :cool:
  4. dilligaf
    Aye mate up north!
    NE England
  5. DCS222
    DCS222 Guest
    Pissing it down in Cumbria this morning... so took seat off and using a cardboard template I'd made, checked dimensions and did a little mock up of solo seat plus luggage rack... seat is nowhere near on the underside, so it's going or being butchered.
  6. DCS222
    DCS222 Guest
    So having a little bored daughters assistance, I marked up and hand tooled the basic shape of the baseplate in 4mm aluminium.
  7. dilligaf
  8. DCS222
    DCS222 Guest
    Snatching minutes here and there, I've bent the base plate to profile (gonna invest in a press to make linear forming easier... one day... when I have a spare pocket full of change : unamused:)
    There are 4 round cap screw heads just where I don't want them, so had to account for that in the forming (last photo) they are still a little proud for when the rubber bump stops come, so drilled 4 relief holes to seat them.
    @dilligaf notice rusting hulk in the corner, awaiting IT's project time! :D
  9. MickEng
    MickEng Noble Member
    Sep 29, 2016
    1,805
    450
    West Yorkshire
    Taking shape DC
    I've just noticed the T.E. Lawrence quotation on your footer note. I've studied TEL, one of my heroes.
  10. DCS222
    DCS222 Guest
    Take one perfectly good Thunderbird solo seat and rip it into its component pieces.
  11. DCS222
    DCS222 Guest
    #31 DCS222, Jun 25, 2017
    Drill out the rear seat brackets, reverse them and re-rivet to bring them closer to your frame width. Create a couple of base plate brackets out of some handy nickel plated steel. Form and create a front seat bracket, drill and tap it to bolt onto seat pan (I may put a safety rivet in to stop rotation forces), the seat pan is marrying up so much better to the frame/base plate now.
    I don't know why the system mixed the photos order up, you'll just have to mentally order the pics, sorry!
  12. DCS222
    DCS222 Guest
    After using some cardboard cutouts as rough templates copied of my main seat. I carved and bent a couple of seat retainer hooks out of the 4mm aluminium. I made them longer than necessary because the base plate and the main seat are totally different shapes n sizes... they needed significant fookin about... but I think I got the final shape n size sorted. I used zip ties for the marrying up rather than rivet them in place 'cos I wanna rub down n smooth up before final spray painting.
  13. steve lovatt
    Good work, good photos - you have been busy!
  14. DCS222
    DCS222 Guest
    Thank you, it never looks much at the end of the day... but these little things take time, especially if you have kids to entertain! Fortunately, either one of mine likes to come in and spend an hour or so tinkering... I feel really lucky that way.
  15. DCS222
    DCS222 Guest
    Finally grabbed some more time, fixed the seat position now and the rear rack... time to put things back together, paint up and fix in position... can't wait!
  16. MickEng
    Sep 29, 2016
    1,805
    450
    West Yorkshire
    Getting there DC and looking good.
    Like the 'butt locator' bolt on the rack. lol
  17. DCS222
    DCS222 Guest
    :yum It's an important safety feature, don't want anyone sliding off the back...:scream:
  18. DCS222
    DCS222 Guest
    Rubbed down, riveted & bolted, ready for final bead basting and spraying... Matt black to match the frame.
  19. DCS222
    DCS222 Guest
    Not the neatest staple job, but I was on my own. The seat with all its modifications is now reupholstered and the vinyl is seated nicely.
  20. DCS222
    DCS222 Guest
    With the base plate painted Matt black but the edges rubbed back to aluminium to match the engine fins... its al ready to put together (no butt locator now!)
