Tiger 900 Gt Pro Dashboard Issues
Discussion in 'Technical Help' started by Sylvain Paradis, Aug 4, 2020.
  1. Steve Jones
    Steve Jones New Member
    May 25, 2017
    10
    Merseyside
    I'm taking mine in on Friday, so it will be interesting to compare notes!
  2. Jim Connor
    Jim Connor New Member
    Aug 31, 2020
    Massachusetts
    Just got back from dealer and they stated the error code show Display Lost communication with the bike computer.
    Bike is fully updated with latest versions
    No other error coded showed up.
    I suspect what happen is like the "Blue screen of Death" on windows
    So at this time there is nothing the dealer can do
    I have not seen the problem again and every works fine.
  3. Steve Jones
    May 25, 2017
    10
    Merseyside
    So I've just got back from the dealer and they have done just the same and pretty much echoed what you where told. They have updated the TFT screen software and updated the ECM. So all good now
  4. mitchrallypro
    mitchrallypro New Member
    Oct 10, 2020
    Montreal
    It's not a dashboard issue but I was wondering if any of you change your indicators. I got a set of 4 of Triumph A9838077 scrolling indicators and installed on my bike and when I use the signal indicators they work great but when I brake i get a notice right indicator problem, I've stopped and test it and the right indicators light up but then it turns off right away when I brake, the left one works great and stays lighted up. I did unplug the battery and replug the indicator, I noticed that when I start the bike and don't use the indicators and brake they work and both light up when I brake but if I turn left or right and use the indicators after that if I brake then the right indicators doesn't light up when I brake and gives me the error message. I switched them around and it works at first but the problem comes back. I've contacted Triumph but they didn't help.
  5. Steve Jones
    May 25, 2017
    10
    Merseyside
    I had the scrolling indicators fitted to my Street Triple RS and you may need the relay unit or sometimes the software will need to be updated so as they work properly.
