Thruxton Thruxton R Gear Linkage Bolt Failure
Discussion in 'Thruxton, Scrambler & Trident' started by timboo, Oct 14, 2022.
  1. SpeedTwin1200
    SpeedTwin1200 Senior Member
    Jul 21, 2019
    261
    Hampshire
    I don't know, but I would be surprised if the ball was ever removed from the socket, cleaned and re-greased. You might find a service schedule with it listed but at best I'd expect a mechanic to inspect the joint for play and replace as required. I'm not sure that you can even lift the rubber boot enough to give it a squirt of grease.
    As pointed out on the other forum link you posted, someone said it's not a bolt. It's a ball joint, with a thread and hex, so the tolerances will be different to a bolt. I've known plenty of rod ends bearings in motorsport fail because, when the lock nut comes loose, the play in the thread allows too much movement and it'll either undo itself or snap.
    If for instance the locknuts on the little gear change rod linkage we are looking at here, between the two ball joint ends, came loose at either end, it would quickly fail for that same reason.
    My key point was that unless a spanner is used that is no thicker than the hex itself, it is easy for a home mechanic to assume the "bolt" is tight when the spanner gets pinched. If the hex is not torqued against the lever, it will only ever be finger tight. No amount of locktight will "glue" that thread in place when put under the loads it recieves. Every gear change and every stamp on the lever to find first gear etc, will rattle the "bolt" thread in the lever and it will come loose and then shear every time. The strength only comes from the length of thread screwed into the lever and crucially, when the hex acts as a locknut, as intended, when it is tightened against the lever.
  2. timboo
    timboo Senior Member
    Oct 17, 2021
    307
    Cambridgeshire
    #22 timboo, Oct 16, 2022
    Thanks I’ve looked through my Haynes manual and my owners handbook and have not been able to locate any reference to any torque settings for the gear assembly, including the gear lever and the hex nut in Q. Could anyone steer me in the right direction of a manual of sorts covering this. thanks.
    Very valid point re the hex nut and the lever and not achieving sufficient torque at the nut. I’m guessing the only way to achieve this would be to remove the lever and secure the lever first.
    Assuming there is a torque setting for the hex is there sufficient space to get a torque crow’s head in there?
    PS what is best for marking up reference points like you have done?
  3. learningtofly
    2,133
    Fair to say that you've been unlucky with this bike. Sorry to hear of your latest issue.
  4. Wessa
    Yes it was the bolt that sheared. In my opinion it is a design/manufacturing fault. Touch wood I’ve not had no further problems.
  5. timboo
    Oct 17, 2021
    307
    Cambridgeshire
    Bizarrely I laughed for several minutes when this happened.
    On the plus side it’s a good way to slowly learn about the workings of a machine makes you quickly realise how well made my previous Jap machines were having never experienced a single issue.
  6. timboo
    Oct 17, 2021
    307
    Cambridgeshire
    #26 timboo, Oct 16, 2022
    several images from feb shows the thread all the way in and cause of mine breaking was due to it becoming loose on it’s own unless it was removed during the service. It then broke as it was under additional stress.
    I don’t believe mine was down to manufacturing defect.
  7. Eldon
    Eldon Elite Member
    Manufacturing defect, no possibly not but could still be an assembly issue.
    I would contact the factory and ask if there would be any assistance with this matter.
    I did when a wheel balance weight removal took out a chunk of powder coating. The wheel was 510 mile old and straight after 1st service I changed the OE tyres.
    They supplied a replacement wheel on an exchange basis, couldn't fault Triumph (or Cobb and Jagger's, the dealer) handling of the matter.
  8. Kinjane
    Kinjane Active Member
    Oct 15, 2017
    242
    Bristol, Land of Enger
    Obviously wasn’t reassembled correctly after the bike went over on the left hand side!
  9. timboo
    Oct 17, 2021
    307
    Cambridgeshire
    #29 timboo, Oct 16, 2022
    Something I fear I will never get the answer to unfortunately although my images in fed show it clearly a lot closer than where it was at point of breakage
  10. SpeedTwin1200
    Jul 21, 2019
    261
    Hampshire
    When I said torque, I was explaining the issue Timboo as like you, I haven’t found a torque value anywhere and nor do I have a tool for that job.
    Torque as in tight enough, using a spanner. I do think there was an assembly issue as when my bike was first out in 2019, there was a spate of gear shift link failures. I’m not sure they used threadlock or maybe the wrong one. Whatever I did has lasted about 4000 miles anyway. But mine did need thread locking and tightening from new.
    Putting in a claim on that basis is another issue though.
    I use nail varnish and nail varnish remover or acetone to wipe it off. It’s basically the same thing but cheaper and easier to get hold of than the official motorsport version.
    It’s hard wearing and you can mark things you have torque checked and differs from the white or blue marker that the dealership uses.
    It’s useful for safety critical fixings where a quick visual check is all that’s needed.
    And sometimes you can see what someone else has touched, or not, at a service etc.
  11. Doofus
    Doofus New Member
    Jul 19, 2023
    2
    Whitestone
    Same bolt sheared on a rideout tonight on my 2016 Thruxton R. Identical to pics on here. Did I see that you can just get the bolt after releasing a circlip? Poor quality to just go like that.
  12. timboo
    Oct 17, 2021
    307
    Cambridgeshire
    Sorry to hear yours has done the same. There was no clip to remove on mine. I just replaced the whole lot in the end. I think the new one was ever so slightly different design wise. Since then added some blobs of nail varnish to anything which may work its way loose in the future and inspect as part of my pre ride check. the new part has not budged since.
  13. Baza
    Baza Elite Member
    Jul 25, 2020
    3,415
    Amazing Grace
    Surely the bolt that shears can’t be that special? Try SS A2 or A4 -80 which has a higher tensile strength.
  14. SpeedTwin1200
    Jul 21, 2019
    261
    Hampshire
    On the Thruxton and Speed Twin etc, if the ball joint part of the gear lever linkage linkage comes loose, it will back itself out until there is sufficient play in the thread to allow it to move and eventually shear. It only has the required tensile strength when fully tightened with the nut (6Nm) against the linkage face. As noted above, a conventional spanner will jam between the socket part and the gear lever arms and maybe damage the rubber dust seal before the ball part is properly tightened, so you need a thin spanner for that job. And some threadlock!
    The same goes for the locknuts on the adjuster rod, also 6Nm, according to the service manual.
