Tail Tidy speed triple 2016 R
Discussion in 'Speed Triple' started by Base, Jan 21, 2017.
  1. Knobby62
    Knobby62 New Member
    Jan 31, 2017
    7
    West midlands
    Mr T, I think you may have the solution. Looking at your pictures I would say that it is an Arrows link pipe for sure. I did however follow the Evotech on line fitting instructions that made no mention of removing a rubber gasket to ensure metal on metal fitting. I will revisit it in the week but if the gasket is "firm" that could make the difference.
  2. MrTriple
    MrTriple One Cylinder Short
    Jan 23, 2017
    927
    Epping Forest
    Amazing. Problem is solved!
    I originally tried the gasket because I thought it would be better with, rather than without, but it definitely needs to be ditched (along with the metal bit that goes with it).
    Here it is for posterity:
    When you fit without the gasket, everything will slot into place - millimetre perfect :)
  3. jonesy
    jonesy Active Member
    Mar 26, 2016
    84
    worcestershire
    Did you refit the rubber gasket it's a thick block that you don't use with the evotech
  4. jonesy
    Mar 26, 2016
    84
    worcestershire
    Note to self ... read all the posts before commenting
  5. MrTriple
    Jan 23, 2017
    927
    Epping Forest
    If you didn't read all the posts, you did a far better job at arriving at a solution than I did. That has to be acknowledged :)
  6. jonesy
    Mar 26, 2016
    84
    worcestershire
    I've got the same tail tidy so had a good idea
  7. ScreaminWargasm
    31
    Glad a just read this thread as I pick up my new Triple R tomorrow and have the Evotech ready to install.
    Cheers for the info guys!
  8. MrTriple
    Jan 23, 2017
    927
    Epping Forest
    I've got an extra installation tip - as you tighten up the four bolts that secure the tidy to the bike, make sure you don't trap any wires (like the thin tail light wires). It will squash them flat or even shear them. Don't ask how I know that.
    Enjoy your picking-up-your-new-bike experience tomorrow - very exciting indeed!
  9. ScreaminWargasm
    31
    Thanks for the tip mate. Also got the rad and oil covers plus the SC Project ovals to install. Can't wait......although rain is now forecast tomorrow which bloody typical.
  10. desertspeedy
    desertspeedy Senior Member
    Jul 28, 2016
    437
    N. Phoenix, AZ, USA
    I think I am the only customer with the R&G Tail Tidy who thinks it is just fine. Our license plates are smaller here in the states and the tail light has integrated blinkers. Evotech was not on offer when I bought it and installed it.
  11. Ali G
    Ali G Member
    Feb 6, 2017
    52
    Kirkcaldy
    IMG_0159.JPG Just a bit of topic but I'm really happy with my r & g tail tidy on my 94
  12. desertspeedy
    Jul 28, 2016
    437
    N. Phoenix, AZ, USA
    ^That looks the biz, I like it!
  13. Woa Shamrock
    Woa Shamrock New Member
    Apr 24, 2017
    Norfolk England
    Hi, I've just fitted my Evotech and the wires have to run through the central channel and also not get trapped between the tidy and the bike when you bolt them together, if any wire is caught between the two the indicators wont clear your carbon . Had a bit of this trouble while fettling mine but sorted it. You've probably figured it out by now though.
    Cheers, Gaz
  14. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Evotech and R&G holders all look great
    But where do you source your mini number plates?
  15. ScreaminWargasm
    31
    eBay mate. They are about £8 and are pretty well made. I've had no issues with mine.
    Mick
  16. Ali G
    Ali G Member
    Feb 6, 2017
    52
    Kirkcaldy
    I got mine from eBay, they're classed as show plates as they are not the official size.
  17. MrTriple
    Jan 23, 2017
    927
    Epping Forest
    I use this seller - the plates are slightly more expensive because they are clear acrylic over the number plate film, rather than film stuck on top of the acrylic plate. Make sure you have bolts though, because they send fixing pads, which are as good as useless.
    They are fast delivery and you can specify exactly what you want when you pay - for example:
    Motorcycle REAR - 8" x 6”
    STANDARD YELLOW
    Registration: AA11 AAA
    Font: 3D HI LINE
    Border colour: Black 1mm
  18. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    Cheers Mr Triple, will refer to them when I get round to sorting my rear end!
  19. MrTriple
    Jan 23, 2017
    927
    Epping Forest
    #39 MrTriple, Apr 29, 2017
    I prefer not to expose my entire rear end on the internet - so here's a cheeky glimpse, for what it's worth.
  20. ScreaminWargasm
    31
    Those carbon parts in the pic look nice mate. Where did you get them from?
    Mick
