Super Or Normal Fuel.
Discussion in 'Triumph General Discussion' started by chuk, Oct 30, 2018.
  1. Rocket
    Rocket Well-Known Member
    Oct 29, 2018
    89
    78
    Connecticut
    High compression engines require high octane fuel!
    My sprint gt enjoys a 12-1 compression ratio....use high octane .....please!
  2. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    Yup
  3. MrOrange
    So you hear it pinking when you use regular fuel?
  4. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Every 5th or so fill up I use premium
    For its enhanced cleaning properties
    When I bought my Speed Triple in the summer, it had done 11k miles over 7 years, it was running quite rough with uneven tickover but after 2 or 3 tanks of premium it was very smooth, like it had just been broken in.
    I notice the popping on the overrun is more noticeable on premium, so something is happening
  5. chuk
    chuk Senior Member
    349
    neilston glasgow
    Okydoky then I will just stick to regular shell 95 got a bottle of redline fuel system cleaner in garage to open,I did see good article about super fuels making genuine measured boost in high performance (scoobydoo turbo etc) cars on fifth gear,but probs on bike make next to no measurable benefits can of worms now closed thanks all.
  6. steve lovatt
    I thought I read somewhere that in the case of the 865 EFI engine it runs worse with 98 octane. Don't waste your money! :cool:
  7. Tiglet
    It’s regular fuel for all my bikes and never had a problem.
    Sometimes Shell regular or even Morrison’s regular, it all depends on which way I’m going on a rideout.
  8. Rocket
    Oct 29, 2018
    89
    78
    Connecticut
    depending on the ecu the engine has.......probably not...the more cylinders, the more detonation....that is what creates the ''pinging'', Lot of good posts here......some not so much.......nothing wrong with this one, :)
  9. Biker Jock
    Biker Jock Senior Member
    Nov 16, 2014
    626
    The BMW minimum recommended fuel for my R1200S is 97 RON, so I was a bit concerned touring Scotland a few years ago, when I was forced to put the normal stuff in (will it like even start???) or run dry. But I didn't notice any difference at all in performance or consumption. Similarly, heading down through France to Spain the next year, it ran mostly on lower grade fuel, with no problems at all. I stick to the recommended grade where it's available, but don't have any worries putting common or garden in if that's all that is available.
    I do agree that there is a noticeable difference in feel, with all the bikes I've owned, on cool, fresh days. I much prefer riding on cool days. The engine is much more eager and crisp. I always put that down to more oxygen in the denser cool air.
  10. Angry Sky
    Angry Sky Well-Known Member
    Sep 7, 2016
    55
    Staffordshire
    One thing to remember is that "super" fuel does not go off the way normal fuel does. So it pays to put a bit of super in before winter if laying the bike up. You real bikers can just ignore this post.
  11. David Cooper
  12. Rocket
    Oct 29, 2018
    89
    78
    Connecticut
    ya get what ya pay for with shell.....no question I use only the best on all my proformance vehicles...lawn mowers and such get the cheap crap.
  13. chuk
    chuk Senior Member
    349
    neilston glasgow
    Good point I don’t use super market petrol but do use their diesel in car with millers additive,yes shells dearer for petrol but for bike anyway it’s worth the extra imho.
  14. MrBojangles
    MrBojangles Well-Known Member
    Jan 22, 2017
    37
    Bucks
    I'd agree with this. As I understand it, the higher ethanol content in the cheaper stuff can cause 'varnish' like deposits in fuel systems and carbs if the fuel is left unused for more than 3 weeks. So for everyday/regular use, cheapo is probably fine. I use premium as I'm a wet blanket fair weather Sunday rider and hence, my trusty lawnmower gets premium as I hate cutting the grass. But when I do, it seems faster...
  15. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    Just to confuse matters further, it depends where you live.......
    Last time I checked the south west is one of the several areas where buying high octane fuel doesn't get you any less ethanol content.
  16. Callumity
    3,358
    The myths abound.......
    All UK petrol is brewed to a common standard EN228 (up to 10% ethanol) and the different retailers’ tankers load from the same gantries. The real difference is in the premium fuel additives which contain more octane boosters, detergents and lubricants of pretty theoretical benefit to a low mileage vehicle without the necessary sensors and ECU.
  17. Almostthere
    Almostthere New Member
    Sep 27, 2018
    Brighton
  18. Jeffrey Conlon
    Apr 4, 2018
    59
    Wakefield
    I agree with you, I would say if it is a better fuel you would get better mpg for a start which is the only way I could justify the extra dosh, if you are not getting anything out of it why bother when the prescribed fuel is quite ok ?
  19. Shellmanstu
    Shellmanstu New Member
    Sep 14, 2018
    Chelmsford Essex
    I work on the tankers, and on Shell, I can tell you that what kind of fuel you’re getting depends on where you are in the country (with regard to normal fuel) There are only two places that provide V Power, Grays in Essex and Shells refinery in Stanlow, so that has always been as it should, but after the Coryton refinery closed, we’ve been getting fuel from all over the place in the South East. Proper Fuel Save fuel has only been available in Grays for the last few months. But stocks are still topped up with generic fuels from Navigator terminal in Thurrock, and from Esso terminal in Purfleet. As for supermarkets, again, depends where you are. I fill up in Asda, they get fuel from Esso, or did till recently, the same goes for the others, depends where they can get the stocks from for the right price. I personally save my cash and get 91 RON.
    • Informative Informative x 3
