SPEED TRIPLE WARRANTY ISSUES
Discussion in 'Speed Triple' started by Col_C, Oct 11, 2016.
  1. Iceman
    Iceman Crème de la Crème
    Apr 19, 2020
    2,391
    Lancashire
    Ducatiortriumph is correct in what he says, remember when fitting an end can exhaust you have removed the second cat, however the sensor is fitted to the front cat so no additional mods are required, unlike the new models all have a one piece exhaust system and therefore you do need the mods and a re map, however this will invalidate the warranty, so fit it as Ducatiortriumph says. I have both a Yoshimura and Scorpion for mine, I switch them round fairly regular as the mood takes me, and just carry out those simple steps. Ride safe all from an ageing Rocker.
  2. BT81
    BT81 Member
    Jul 31, 2021
    73
    Lichfield
    The bike is getting picked up by the dealer this week. Let's see what the issue is. Hardly confidence inspiring.
  3. Bmwjay1000rr
    Bmwjay1000rr Member
    Jun 23, 2021
    24
    Cambridge uk
    2021 speed triple 1200rs
    New petrol tank ( paint defects)
    New engine Cases
    Fuel gauge stopped working
    Low oil pressure warnings
    New gearbox
    Intermittent starting problem (been at dealers at month now)
    New starter solenoid
    New switch gear
    New wiring loom
    All this and the bike's only covered 8,000 miles......and triumph UK reckon its "Fit for purpose ".....which I'm on going dispute with them.......WOULD NEVER BUY TRIUMPH AGAIN.....
    • Useful Useful x 3
  4. timboo
    timboo Senior Member
    Oct 17, 2021
    307
    Cambridgeshire
    #224 timboo, Oct 12, 2023
    I jad an interesting conversation today with an independent garage. They said that modern bikes have a lot more sensors and that the sensors cannot cope with pressure washers, also the wiring loons are made from smaller csa cables since the led evolution ie will not last as long as older bikes.
    This is the first and only Triumph I too will ever own just too unreliable.
  5. Bmwjay1000rr
    Bmwjay1000rr Member
    Jun 23, 2021
    24
    Cambridge uk
    Timboo
    I pm you
