Speed Triple Rs 4th Gear Problems
Discussion in 'Speed Triple' started by Albi, Apr 23, 2019.
  1. SteveRS
    SteveRS First Class Member
    Jan 12, 2019
    862
    British Columbia
    The 4th gear issue has the bike reving up in that gear when hard on the throttle. So shift into 4th and then start accelerating hard and most of the time the bike will rev up without putting the power down. That can be a very dangerous situation. This has happened to a number of us after experiencing the false neutrals resulting in the gear dogs smashing into one another. The dealer said mine were damaged pretty bad when they pulled it apart.
  2. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Have you read through this thread from the beginning, because this has been discussed at length here. To fix my bike they were waiting on parts to rebuild the gearbox, no other way to fix the issue. I wrote the CEO and received a replacement bike. Mine sat in the shop for over three weeks with nothing being done. Unacceptable. Your gearbox will most likely need to be repaired or completely rebuilt by the sounds of it.
    As far as the quickshifter issue, aftersales and the dealer can’t help, as they have no idea as to what the real malfunction is. Their BS fix is the shift arm replacement, which did not fix the issue on either of my bikes. If you have a bike that doesn’t have a malfunctioning quickshifter, you’re lucky. If you do, you’re $h/t out of luck.
  3. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Well they did give me a replacement bike, which was the right thing to do, it’s just too bad they can’t fix the malfunctioning quickshifter issue. Cheers and good luck.
  4. kazzz
    kazzz New Member
    Jun 3, 2019
    17
    Belgium
    Little update from our side:
    We drove yesterday 500km's and guess what:
    - 0 false neutrals for both our bikes
    We are mild optimistic they solved our issue. What they told us was they changed the gearbox completely.
    I'll keep you updated.
  5. Dickie
    Dickie Active Member
    Jun 8, 2016
    128
    Tadcaster, North Yorks
    Are the QS & 4th gear issues related or separate?
    I'm thinking of px'ing my 09 Aprilia RSV1000R & 15 Speed R for a 19 Speed RS (without QS) but I'm nervous although the none Triumph dealer is offering 2 years or 5k miles warranty.
    What do you unfortunate people think?
  6. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
    go for it. BUT....
    I'd like to keep the aprillia though if I had the choice though.
    Just take it out (or a loaner) to see if it's worth it first though.
    Not sure about the 5k mileage warranty?
    I thought it was 2 year, unlimited mileage as standard???
  7. Dickie
    Jun 8, 2016
    128
    2 year/ 5000 mile warranty on a used bike from a non Triumph dealer.
  8. kazzz
    kazzz New Member
    Jun 3, 2019
    17
    Belgium
    Again little update: drove another 100km without false neutrals.
    Could it be the gearbox was the issue, and not the QS???
  9. Rspete
    Rspete Elite Member
    Jun 17, 2018
    1,794
    743
    Durham
    If it's an older 19 plate colour scheme definitely, the rs is a great bike, without the q's.
    The new colour schemes are absolutely disgusting imo.
  10. Dickie
    Jun 8, 2016
    128
    Yes, its old white - I'm with you on the new colours, I wonder if it effected sales?
  11. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I’m unaware of anyone having fourth gear issues without having the quick shifter issue prior. The fourth gear issue is a result of damaged dogs in the gearbox from the quick shifter issue. So it should be a safe bet if you get one that’s never had a quick shifter on it.
  12. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Sounds good. How have you been using the quick shifter? Any full throttle very high rpm shifts? These are the shifts that I had problems with. Low RPM shifting was never an issue.
  13. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
    Hi @SteveRS,
    I've had this ONCE on a st-rs when giving it gas in forth.
    Only the once but horrible sound and crunch.
    I bought the bike with just 680 miles on it from a triumph main dealer.
    I'm now on 4850 without further incident but its a horrible sound.
    I can't tell if it had a qs on it before I bought it but I did mention it to the dealers when it was in for a service and the two triumph engineers looked at each other....
    They didn't notice that i'd seen them....
  14. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I didn’t know Street triples were also having the quickshifter issue.
  15. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
    Sorry. I meant speed triple
  16. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Oh ok. So let me understand, while applying the throttle in 4th without shifting, the gearbox made a terrible crunch sound? So what happened? Doesn’t sound like the 4th gear spinning up issue, because all that happens is the engine revs up with no power to the rear wheel. Sounds more like a quickshifter issue, but the bike doesn’t have a quickshifter, if I’m understanding this right. Sorry but I’m not following you on this. Please explain.
  17. Wayne Kitson
    Wayne Kitson Member
    May 16, 2018
    38
    England
    Had the qs arm mod done on Thursday first proper ride on the speedy today last 40 miles off the day 4th gear issues like slipping clutch or slack chain around 4-5000 rpm
    Hope to god it’s not chilled a tooth as it missed a few gear changes today on the quick shift ffs
  18. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Sorry to hear that. Not sounding very good. Stop using the quickshifter and keep an eye on the 4th gear issue. If it happens again take it back to the dealer. Was there an issue prior to the arm change?
  19. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Good to hear. After the repairs are done, deactivate the damn IED and enjoy your bike.
  20. Wayne Kitson
    Wayne Kitson Member
    May 16, 2018
    38
    England
    No I had no issue b4 it was changed
    it did used to sometimes miss the gears and crunch the box but never had 4th gear issues till today
    I’ve sent them an email At my moto York as shop is closed
    and bike runs out off warranty on Monday
