Speed Triple Rs 4th Gear Problems
Discussion in 'Speed Triple' started by Albi, Apr 23, 2019.
  1. SteveRS
    SteveRS First Class Member
    Jan 12, 2019
    862
    British Columbia
    Where are you at in Canada? If your dealer won’t help you, then contact Triumph Canada directly. They have to be aware of the issue by now. You could also contact the CEO of Triumph if Triumph Canada is no help. His email is in this thread I believe. Stop using that bloody quickshifter immediately or you will destroy your gear box. If you haven’t read this whole thread, then do so please. My gearbox was badly damaged after about 6 false neutrals, as the slamming into the next is brutal on the gearbox.
  2. Luke_88
    Luke_88 Well-Known Member
    Mar 21, 2018
    41
    Canada
    I live near Montreal. I've been in contact with a couple Triumph guys in Georgia, I managed to get an extra year of warranty. Now, they're asking me to get a second opinion from another dealer. More time not riding, more explaining what the issue is. To be continued...
  3. SteveRS
    Jan 12, 2019
    862
    British Columbia
    That’s shitty, good luck.
  4. shandyboy
    shandyboy New Member
    Jan 6, 2019
    Newcastle;
    Luke my 4th gear went due to false neutrals buddy Steve is 100% right it will destroy your Box Triumph know about it. Ive asked for a new bike and my local dealer is trying to sort it out now.
    Send a letter to Triumph Uk and demand they sort it out before you take legal advice (remember social media is a good thing).
  5. shandyboy
    Jan 6, 2019
    Newcastle;
    Well all sorted picked my new bike up on Thursday it was 15 month old with 4k on it. Did not want it back if they strip it down would have no confidence in it if that happened.
    Dealer has been fantastic had to pay a bit nominal amount towards replacement (fair use policy) but well happy.
    After 1st service they are fitting a new quickshifter as there on back order,told them not to use old one Happy Days !!
  6. Luke_88
    Mar 21, 2018
    41
    Canada
    Wow, that was quick. Can you walk me through how you got Triumph to give you a new bike? They're treating me like I'm being difficult and downplaying the issue entirely.
  7. shandyboy
    Jan 6, 2019
    Newcastle;
    Luke my dealer in the UK was great and sorted it all out.
    My 4th gear was shot beyond what I classed as fit for purpose repair.
    Is yours the same ?? or just hitting false neutrals ? My mates bike is doing the same hitting false neutrals and they have a fix for it, that has been sorted by dealer too.
    They replaced some type of gearbox rod by removing the case and a new Quickshifter.
    Try contacting the Triumph Factory direct
    [email protected]
    Factory Tel 01455251700
  8. SteveRS
    Jan 12, 2019
    862
    British Columbia
    glad you got it sorted. So are you saying the fix is more than just a quickshifter replacement? Is there a rod in the gearbox that has to be replaced on all of our bikes to make a quickshifter work properly? I’ve had two different quickshifters with two different gearboxes and neither of the quickshifters work properly. I will never use another Triumph quickshifter.
  9. Burny_13
    Burny_13 Active Member
    Jun 16, 2019
    67
    Reading
    I too would be keen to know what this "rod" that was replaced is?
  10. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Yup, the first time I’ve heard anything about a rod. Sounds like triumph is scrambling for a fix. If they used a quality shifter from the start they wouldn’t have these problems. HM comes to mind.
  11. Sandi T
    I would like to know about the replaced rod too, shandyboy. I had my quick shifter replaced about a month ago and so far my bike is shifting beautifully using the QS. However, if there's another part that could/should be replaced, I'd sure like to know about it and do just that.
  12. shandyboy
    Jan 6, 2019
    Newcastle;
    Steve not sure on the full story, All I know is my mate had the false neutral problems but his 4th gear was still good, He booked it into Triumph to sort out and they fitted the new part that's been machined out and it made no difference he was still getting the false neutrals.
    He returned the bike back to the dealer and they took an end cover off and said it had bent/worn away some type of shift rod?
    They ordered a new part and a new quick-shifter too, he has used the back for the last week and it's perfect no false neutrals and said its transformed the bike says gearbox feels super smooth, never been as good and the blipper is perfect. (and he rides it hard!!)
    I will call into my dealer before the end of the week and see what the part was if that helps
  13. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Sandi, I’m glad to hear the new quickshifter is working out for you.
  14. shandyboy
    Jan 6, 2019
    Newcastle;
    Steve I've been told the Triumph quick-shifter is made by Translodgic so it should work good. My mates is perfect now
  15. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I just googled translogic and they appear to use strain gauge technology in their quickshifters. If that’s the case then there’s something wrong with our gearboxes.
  16. Sandi T
    Hmmm, things get curiouser and curiouser. :confused:: unamused:
  17. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I have a whole new gearbox and new quickshifter, and I still had two false neutrals. ?? Triumph has a major problem on their hands here with no fix in sight.
  18. shandyboy
    Jan 6, 2019
    Newcastle;
    Will see what they replaced on my mates bike works perfect now. says its better than when it was new !! so his is sorted
  19. Sandi T
    Yes, it would be great to know what they replaces on your mate's bike. Please let us know when you find out! Thank you. :)
  20. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I think I may have mentioned this before, but do any of you who are having an issue with false neutrals have a slight grinding feel to you shift lever? If you very gently move the shift lever up or down by hand, can you hear or feel anything? I have a slight rubbing or grinding sound and feel. If the quickshifter is even slightly touching anywhere, it could certainly compromise its performance. Please let me know if your bike is doing the same.
