She's No For Starting- Help!
Discussion in 'Technical Help' started by d-basser, Nov 25, 2017.
  1. d-basser
    d-basser Active Member
    Apr 7, 2016
    159
    Glasgow
    Cheers, I've actually cleaned the side stand switch already. Will double check with a multi meter that it is working. Tried bypassing the side stand switch just incase but no luck. Clutch switch appears fine with a multi meter but I'll give it another look
  2. TEZ 217
    #22 TEZ 217, Nov 26, 2017
    I agree Dan, thats why I asked about kill switch, try the battery route then you need to trace a possible fault/broken wire in the safety circuit (which can sometimes be difficult with a meter as a broken severely frayed wire can give you a positive reading of continuity on a meter, but when its activated or a load put upon it - it will fail !! )
  3. dilligaf
    C'mon Dan...British pride is at stake here :eek:
    If Samuel F turns up at yours with a running bike...you've lost :(
    If you get yours going first then you've won :cool:
    C'mon get your finger out :mad:
  4. d-basser
    Apr 7, 2016
    159
    Glasgow
    #24 d-basser, Nov 26, 2017
    If Sam turns up with a working bike he's paid a man to fix it :p
  5. d-basser
    Apr 7, 2016
    159
    Glasgow
    Aye looking forward to a fair bit of fault chasing :oops:
  6. TEZ 217
    So are you getting the bus round and starting on Sam's first then ? :rolleyes::rolleyes:
  7. Callumity
    3,358
    A couple of connectors to wiggle/clean - one in headlight shell, one under tank. I am off to study the wiring diagram to narrow down other possibilities!
  8. Callumity
    3,358
    #28 Callumity, Nov 26, 2017
    Right..... the two inoperative bulbs share a feed via the headlamp connector to the igniter so there is a possibility of an igniter failure. You can only test by substitution. However, another possibility is the ignition switch where the terminals separately energise the ignition and, when pressed, the starter circuit.
    Before stripping anything do load test the battery.....but should have got netral and oil lights even if it would not crank.......the relay sounds healthy if it clicks.
    HOWEVER.........
    IF I read you right, the fact your netral light responds to grounding the cable might be a clue. It is a simple plunger switch and part of the safety circuit. If you pull the connector switch ignition on confirm voltage to earth with your multimeter. If you ground it and get a green light all well and good; if not you have a faulty switch and ignition lock out.
  9. Sprinter
    #29 Sprinter, Nov 26, 2017
    You both live within the same weather and the cold hit last week. down to minus and frost. Too much of a coincidence, eh.
  10. d-basser
    Apr 7, 2016
    159
    Glasgow
    Not got it running yet, popped a fresh battery in but no joy. Beginning to suspect it is a wiring issue so may have to spend tomorrow chasing that
  11. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    Hope you never meet his missus DD, think yo might be missing a few body parts if you do
  12. d-basser
    Apr 7, 2016
    159
    Glasgow
    I could barely convince her to come hold things whilst I put new bulbs in her car for winter so doubt I'll get her out aiding with the bike
  13. STIFFLER
    STIFFLER Senior Member
    Jan 27, 2015
    593
    143
    Shropshire
    I have similar symptoms to this d-basser on a 91 Daytona 1000. On mine its either the wire from the battery to solenoid or solenoid to starter? If I wobble the solenoid ALL works fine but move it again & nothing!
  14. d-basser
    Apr 7, 2016
    159
    Glasgow
    Thinking it must be something like this. Not had time to go through wore wiggling unfortunately.
  15. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    No time to wiggle your poor missus:cold_sweat::scream::p
  16. MrOrange
    If she not wiling to hold it for you, that is one way to go!!!!! :p
    Let us know if you get it sorted, we like a happy ending. :)
    But they do charge more for that :eek:
  17. Sprinter
    Hay. Whats new?
  18. MrOrange
    Donald Trump is the biggest Arsehole to ever breathe....... allegedly.
    Except for the bigger arseholes that thought he would make a good president......... Allegedly.
    How am I doing?
  19. Sprinter
    d-basser, see this is what happens when you leave your threads unattended.
  20. crispey
    The yanks have the same thought although they do like to feel they’re related, only cos it makes them feel intelligent in comparison!! B99F0A13-41E5-41D5-AF32-306CE998AED5.gif
