Really Strange Demonic Fault, Help And Advice Needed!!
Discussion in 'Speed Triple' started by Shaun Lee, Apr 1, 2020.
  1. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Diesel
    My suspicion is wrong fuel
    Then after numerous starting attempts battery has got low
    Give the battery a good charge
    Put some Sea Foam or RedX for petrol in a high concentration in the tank with some premium unleaded and turn it over to ensure all remaining fuel in the rail has passed through
    Sea Foam can cause it to smoke quite a bit but cleans everything up well
    Just a thought
  2. freck
    freck Elite Member
    May 4, 2017
    1,718
    Preston, Lancs, UK
    This from RT sounds likely to me, seeing as your problem started as soon as you’d refuelled. : unamused:
  3. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    And don't forget to clean the spark plugs o_O
  4. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
    I had a hayabusa that did this (gen 1 type) and it turned out to be the fuel hoses collapsing.
    Fuel would be blocked off until it was switched off and on again.
    I replaced the hoses and viola, worked.
    Very frustrating as it'd do 5 miles and then stop with no codes. Gave it a few mins, and all was good again.
    Start it up with the tank propped up so you can actually see the hoses.
    Good luck!
  5. Linx
    Linx Well-Known Member
    Mar 14, 2020
    198
    Stratford Upon Avon, UK
    What was the outcome on this Shaun?
