Oil On Rear Fender
Discussion in 'Newbies Hangout' started by Joe D, Apr 28, 2020.
  1. RevPaul
    RevPaul Senior Member
    Apr 21, 2020
    753
    Cheshire, UK
    I'm with you on that. Shaft or Belt drive has got to be better.
    I've just spent an hour or so cleaning the oil fling off the back of my bike (wheel, seat cowl, frame, silencers etc). I obviously over interpreted the instructions on the can that said "ensure all surfaces of the chain are coated". So having now learned that less is more, what's the trick to apply just enough lube?
  2. Alatamoc
    Alatamoc Senior Member
    Mar 29, 2019
    493
    If there is one, I haven't found it in 50 years of motorcycling.
  3. Dartplayer
    I apply to a chain brush and then to chain. If chain is dirty, I use WD40 on a rag to clean
  4. Wessa
    They are ok, but you have to be a little careful with them, cause apparently you can damage the chain if you are to aggressive with the brush.....
  5. SprinterII
    SprinterII Noble Member
    Mar 27, 2020
    642
    Scotland
  6. Wessa
    It was one of the tech’s at a local bike repair shop. Said if you are to aggressive you could damage the o-rings. No reason to doubt him.
    • Creative Creative x 1
  7. Wessa
    Nope, it was a passing comment in conversation about chain cleaning...
  8. dreitopf
    dreitopf Active Member
    Feb 27, 2020
    185
    33
    Germany
    I habe a cheap scott oiler ...my chains are running more then 45 T km and I only use cheapest mineralic Chainsaw oil..one Liter 3 Euros.For cleaning a old towel full of engine oil.Works perfekt...is cheap and nearly no oil on wheel and tire.WD40 is agressive to the o ore x rings.
