Is This Head Gasket Blown?
Discussion in 'Technical Help' started by StuarT595, Jan 18, 2021.
  1. StuarT595
    StuarT595 Active Member
    Nov 19, 2020
    204
    South West UK
    Makes perfect sense to leave it out after reading this...many thanks for that and the encouragement. Will put the thermostat housing back together using the old sealing ring for now then
  2. StuarT595
    Nov 19, 2020
    204
    South West UK
    Re the valves, I’m definitely beginning to think they were the culprit to the rough running and poor starting, especially as the exhaust gasses have made it back to the air filter.
    Thanks for the backflushing update...yes, I see now, and have already hosed the rad in both directions, but a good cleaner will still be needed I’m sure...I wonder about filling it with coke or similar, just to give it a head start?
    I’m looking for a company in the Bristol/Glouc/Stroud area today to see what’s available re a head clean because I too feel it would be a good idea.
    Cheers Adie...appreciate all your insights!
  3. Adie P
    Adie P Crème de la Crème
    Jul 7, 2018
    3,709
    MID DEVON
    Pleasure!
    Try these people for the head/test clean .... http://www.pricebrosengineering.co.uk/ That's just from a google search but worth a 'phone call.....
    I think filling the rad with cheap cola and leaving it overnight, then flushing thoroughly is unlikely to do any harm .... unless it's on it last legs anyway - in which case it's better to find out now rather than at 100 miles away and 70 miles per hour? ;)
  4. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    A good way of getting the cooling system clean is to flush with a weak hydrochloric solution (alloy wheel cleaner) but if it's not terrible which yours isn't seen one hell of a lot worse by the looks of it just a flush with a strong detergent and hot water, another option is a caustic solution but if left it will eat alloy.
    When flushing you want no obstructions so thermostat removed as said, as for the air filter smelling of fumes does the evap/breather system run back to the air box? (usually does) bad ring seal etc will result in the smell although this is likely to happen to a degree anyway due to the way the system works.
  5. StuarT595
    Nov 19, 2020
    204
    South West UK
    Really appreciate this, TD...I’ll definitely upgrade my understanding of the evap system.
    There was a small amount of dark, sticky residue coating the inlet manifold, worse in the nearside manifold, which is what first made me think exhaust gases might be venting past the inlet valve? I guess I’ll know a little more when I remove the inlet valves today...hopefully it’ll be obvious if one or more of the valves have been bypassing?
    Many thanks again...such a fantastic forum, so much Triumph knowledge in one location.
  6. StuarT595
    Nov 19, 2020
    204
    South West UK
    Have taken a look...they look promising, will call them later...thanks so much
  7. Yorkshireman
    The breather/evap system will smell of old hot oil if it’s been doing it’s job right and could smell like exhaust.
  8. StuarT595
    Nov 19, 2020
    204
    South West UK
    Ah, OK...another piece in the puzzle...many thanks :)
  9. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    It would be very unlikely that the smell would be due to badly seating inlet valves due to the way the engine works...just an air pump I have seen it from bad valve timing and spitting back but I strongly suspect what your smelling is the result of engine breathing....you will usually get a bit of residue just from petrol vapour alone anyway.
  10. StuarT595
    Nov 19, 2020
    204
    South West UK
    Sounds like good news, I could be getting a little paranoid with this engine...it may even be a ‘good un,’ I just don’t know it yet!
  11. speeder
    speeder Noble Member
    Jan 3, 2019
    409
    313
    dorset
    You can skim the head on OHC engines,it just means the entire head and cams are just a few thou' lower...this is easily taken up by the cam chain tensioner.
    I've looked at the pictures but difficult to discern much.
    I always get the components scrupulously clean first and then start inspecting them.
    From what you say l suspect the tight valve clearances are a major factor in the rough running issues.
  12. StuarT595
    Nov 19, 2020
    204
    South West UK
    M
    Many thanks for taking a look, much appreciated. Luckily for me the head doesn’t even take a thou beneath an engineer’s straight edge, and doesn’t have any corrosion/imperfections. It’s currently with the engineers for a steam clean and pressure test
    I don’t know where I read it, but I always thought the problem with skimming the head, where cam bearings were integral, was that the cams were left running in an arched head? I could’ve totally made that up, but it kind of makes sense? I’ve put an exaggerated picture of my possibly/likely flawed understanding below.
  13. speeder
    Jan 3, 2019
    409
    313
    dorset
    Yes, it's all a question of severity, anything more than a few thou and the head is probably scrap, when l used to do them we used to skim only the minimum to clean up and then check the cams still turn freely with caps bolted up.
