Inconsistent Brake Pressure
Discussion in 'Speed Triple' started by SteveRS, Apr 12, 2019.
  1. SteveRS
    SteveRS First Class Member
    Jan 12, 2019
    862
    British Columbia
    Update: Until I had the new pads put in, the dealer tried bleeding them which did nothing. I had zip tied the brake lever a few times, which got rid it for a short while, but a very small amount did return. Now with the new pads installed and after several rides I can happily say the issue is gone. Unfortunately the brakes still squeal though, although not as much. I’m not sure how or why this has occurred. If it’s having thicker pads push the pistons further in, so they can’t retract as far after a lever pull, that doesn’t make sense because the original pads would have been just as thick. Maybe as the new pads wear down the issue could return. Who knows. If I change out the pads next year to EBC, that would be a good test.
  2. komp
    komp Member
    Sep 10, 2019
    44
    essex
    well 8 months later and pads have same issue again.
    so clearly whatever they put in as a replacement under warranty have exact same issue
    bike is now out of warranty but think still going to give the dealer a call for a moan.
  3. Zaico
    Zaico Member
    Jul 10, 2020
    36
    Sweden
  4. komp
    komp Member
    Sep 10, 2019
    44
    essex
    cheers. that is an interesting read. and would explain why replacing the pads appeared to fix the issue, but has now returned over time!
    although also sounds like i would have little chance of getting triumph to fix, especially as now out of warranty.
  5. SteveRS
    Jan 12, 2019
    862
    British Columbia
    #45 SteveRS, Apr 28, 2021
    I need to update this thread, as I forgot to add to it last year. I did mention it in the warranty issue thread but forgot to add it here. Last year I took the callipers off and removed the pads, pumped the pistons out and cleaned them. After this process the brakes were very good. There was a very slight difference between the first and second pull but not much. Once Triumph put the replacement pads in it seemed even better. Recently I performed the same process as stated above except this time I put brake grease on the pistons. The pistons were then worked back-and-forth to move the grease into the piston housing of the calliper and the remainder wiped off. Upon grabbing the brakes now there is absolutely no difference between a first and second pull. I have not ridden the bike yet due to weather but will update after riding. I found when I had the callipers off the first time last year and was pumping the pistons out I noticed one piston on each calliper was virtually stuck in place and didn’t want to move. I think this “may” be the reason for that inconsistent break feel. This time when I perform the same process I did not notice any piston sticking, but with grease applied and worked into the calliper, I’m sure the piston movement will improve and hopefully the rubber seal will get some of the grease as well. Here’s a photo of when I was applying the grease to the piston. For anyone that wants to see the process check out my recent thread on cleaning and greasing brake pistons.
  6. komp
    komp Member
    Sep 10, 2019
    44
    essex
    cheers
    i did end up ordering some new pads yesterday
    so before i fit i will take a look at the pistons and see whats what.
    i have plenty of red rubber grease, as used to strip and clean my calipers every couple of years, that was when i used to ride in winter.
    don't really want to do that on the RS, so if easing a bit between pistons and seals is an option that would be good!
  7. SteveRS
    Jan 12, 2019
    862
    British Columbia
    I would definitely give them a cleaning first though. You’d be surprised how much brake dust gets in there in a relatively short period of time.
  8. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Ok, l got out for a four hour ride today on some extremely beautiful and quiet canyon roads. The brakes are working great. There is no issue at present regarding the inconsistent pressure. The brakes feel extremely strong with great modulation. They are not squealing at the moment either, not sure why. Maybe just realigning the callipers on the rotors helped, who knows. If anything changes I will update.
  9. komp
    komp Member
    Sep 10, 2019
    44
    essex
    well in the end just gave the brakes a clean and gave the pistons a greasing.
    figured would give me a better idea if it has worked if I left existing pads in .
    the pistons were not moving particularly freely, which based on what i had read was consistent.
    although is not right for a bike of its age/mileage.
    i was dubious, as even after the clean and greasing, they were only in and out moving slightly better
    i did also need to give the system a bleed after as managed to pop one of the pistons out while cleaning.:no_mouth:
    But took it out for a quick run round town and brakes were great!
    only did about 10 miles, but plan to take out in anger this weekend
    so for now will keep the brembo pads in and see how it goes
    much cheaper than a caliper rebuild!
    thanks steveRS
  10. Iceman
    Iceman Crème de la Crème
    Apr 19, 2020
    2,569
    Lancashire
    The Brembo's work at optimum when braking fairly hard, that's the whole point of these callipers, they won't squeak then, personally I only ever put a very small amount of appropriate brake grease on the edge of the pads (during oscillation), and sparingly, remember all the brake dust, road muck etc etc will stick to anything put on the pads, especially the backs, I have seen some people use that much copperslip it was all over the pads and callipers. The recall to replace the pads on machines with Brembo Brakes was a precautionary measure due to a very small risk of the bonding securing the material coming away, it affected all make and models eg, Honda, Ducati, Aprilia, Kawasaki etc etc. Ride safe all.
  11. SteveRS
    Jan 12, 2019
    862
    British Columbia
    It is odd that the pistons don’t move freely with such a new bike. Maybe that’s consistent with most calipers, idk as this is the first bike I’ve cleaned the piston calipers on. That’s too bad one piston popped out on you, was it difficult to reinstall? As far as movement after cleaning and greasing, I found I had to push the pistons in and out many times to get them to move freely. After that they would all come out very easily when applying the brake lever. Did you do that? Well I’ve had a few more rides since the clean and grease and they are still performing excellent with no inconsistency. One thing that kinda took my by surprise on the first ride after the clean and grease was the initial brake engagement seemed quicker and braking felt stronger. I didn’t mention this earlier because I thought it was probably all in my head, but after several rides it’s still noticeable. Let me know if you feel any difference.
  12. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Yup work phenomenal under heartbreaking. I agree get those pads changed out because it is a potential safety issue. Question though, what do you mean by putting grease on the “edge” of the pads? Do you mean the back side of the pads on the outer edge? Personally I don’t use grease anywhere near pads, as you risk contaminating pads and your safety. After I cleaned and greased my pistons I used brake clean quickly all over to make sure there is no grease anywhere.
  13. Iceman
    Apr 19, 2020
    2,569
    Lancashire
    Hi SteveRS, it is a very minuscule amount on the outer edges of the metal backing of the pad that come in contact with the calliper, and it is minuscule, it amounts to a very fine film, it's not grease based but a very high temperature copperslip, in such small an application it would not contaminate anything at all, to the naked eye you would not know it is there, under really hard braking the pads can push back (thankfully I have never had this happen), in most cases it happens whilst racing on closed roads like the TT, UGP and NW200 where speeds are in excess of 200mph and braking hard down to 60 or so, that's not the case for riding on public roads as we have speed limits (apart from certain roads in the IOM) where there are derestricted sections, although you need to be aware of your responsibilities within the local laws on the RTA, riding over the derestricted mountain section is amazing, there are big drop offs, walls, fences and livestock to throw in the mix, it is also 2 way traffic (apart from TT fortnight when it becomes one way. I am over there again in late June and looking forward to some great riding. It sounds like there are great roads out where you are.
  14. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Ok, on the back of the pads. That was a thing for a while. I tried it on my previous pads but didn’t help with the squealing. I’m not sure what you mean by the pads can push back. At speeds of about 230 km’s per hour with hard braking I never noticed anything from grease on the back of the pads vs no grease. I do notice an improvement with grease on the pistons though. I will continue this process moving forward.
  15. SteveRS
    Jan 12, 2019
    862
    British Columbia
    Putting grease on the pistons was the best thing I could have done. The inconsistency is completely gone and the brakes are feeling stronger than ever. Hey I heard a funny joke the other day that is appropriate at the moment. Did you hear about the guy who was addicted to brake fluid? He said he can stop anytime.
  16. cheapskate88
    cheapskate88 New Member
    Nov 21, 2022
    Washington, DC
    Sorry to have to revive this thread, but I have a 2018 Street Triple that is experiencing the same thing. Brakes have been bled three times.
    If you all haven't had the opportunity and are in the US, I suggest reporting this problem to the authorities. You can follow the procedures over at Triumph Rat https://www.triumphrat.net/threads/16-speed-triple-front-brake-issue-brembo.953404/post-2004129228
    The issue is been taken seriously, even if Triumph has been slow to respond. But the more reports, the greater likelihood something will happen.
    Cheers
  17. Linx
    Linx Well-Known Member
    Mar 14, 2020
    198
    Stratford Upon Avon, UK
    I don't have the issue anymore. I'm not actually sure if it's because I cleaned and greased the pistons or If I've just got used to it.
  18. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
  19. cheapskate88
    Nov 21, 2022
    Washington, DC
    There were several people over at Triumph Rat that did the same, but that solution was short-lived. The problem eventually came back for everyone. Apparently, the piston and the seals are just of lower quality and are sticking when the brake lever is initially pulled...I'd be curious to know whether you've in fact just gotten used to it.
    This is super interesting. It's like a permanent zip-tie fix... Constantly applying tension keeps the pistons loose..?
  20. Linx
    Mar 14, 2020
    198
    I'll let you know in the Spring :)
