Featured Here we go.....Pics Finally - 2011 Speed Triple
Discussion in 'Speed Triple' started by R_1000, Sep 23, 2016.
  1. R_1000
    R_1000 Elite Member
    Sep 2, 2016
    1,476
    700
    UK, London
    Darkman. ..do I just pour the fluid into the new pot, swap and no bleeding required?
    I think black pot will stand out nice with the red subframe?
  2. darkman
    As the pot is above the cylinder you just place a cloth under it and clamp the hose above the cylinder, remove pot and hose in one go. There will be fluid sitting in the top of the fitting that the hose came off stopping air from entering the system, now refit the new pot and pipe and refill with brake fluid very slowly ;) Oh and refit new lid.
  3. Pabs
    Pabs Well-Known Member
    Mar 31, 2016
    38
    78
    Plymouth
    i think the 2016 subframe polished caps from the r would look nice as well
  4. R_1000
    R_1000 Elite Member
    Sep 2, 2016
    1,476
    700
    UK, London
    I need to look into that ;-)
  5. Pabs
    Mar 31, 2016
    38
    78
    Plymouth
    have a look at one of my old threads... cheap if you order the kit minus the silicone tube and add your own
  6. Yorkshireman
    After changing the reservoir half fill it with fresh brake fluid ( new stuff from a sealed container) then push on the brake caliper so that the piston is pushed back into the caliper hence "back bleeding" so any air trapped in the hose is pushed back up into the reservoir. Press the brake pedal until it is firm then top up the reservoir to the correct level.
