Hello - 2001 Speed Triple Owner
Discussion in 'Newbies Hangout' started by Gordon MacBean, Nov 16, 2021.
  1. Gordon MacBean
    Gordon MacBean Active Member
    Nov 16, 2021
    159
    Welling, KENT
    It is not so much an attention to details but that these things are getting my attention because they really have to be done! And I've got the time and energy to do them. It gives me a much needed change of pace and focus.
  2. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    The swingarm sockets arrived today! Weather was good, so I decided to give it a go as it is also my day off. Outer nut on the way out.
    Inner nut coming out...
    Out it is!
    Old swingarm
  3. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Spindle needs a rubdown, clean and grease!
    Hole waiting for swingarm. Chain looped out of the way.
    New swingarm in. Spindle, brake and hub back on.
    Rear wheel back on. Needs to be torqued up. Lovely new seals, bearings and grease grease grease!!!
  4. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    BTW, does anyone know where you can buy T2200039 exhaust gaskets? They are silly money via eBay in Italy and that is just not feasible.
  5. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    The old sleeve from the swingarm is shifting! I will be able to clean up the swingarm and droplinks and have a spare set ready to go. Nice that I also have a decent draglink as well now. Full set of bearings ready to press in as well.
    I used a touch of exhaust paste to quieten the header leak. Just needs a little bit more and it is sorted for now. Easy to remove when I do the studs/nuts in winter project time.
    Washed and polished (car too).
  6. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Managed to buy exhaust gaskets for the bike!! They are rather rare and the other source was Italy, with huge markup and extortionate shipping fees and taxes to pay. Would work out at £40+ per gasket. I got all three for £25 delivered. Still expensive (they were £6.99 when Triumph stocked them).
    Also got new studs and nuts, so need to get an extractor to the old studs out. Will loosen the radiator, so I have enough space to do the work.... But not yet! Might keep this as a winter job.
    When riding home this day, I managed to be rather "un Vicarly" and had the front wheel floating up under hard revs... Sorting the suspension at the rear has given the bike a much better feel and response.
  7. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    The gaskets, studs and nuts are here. Now I need to decide whether I pay someone to do this bit or get an extractor to remove the studs.... decision time!
  8. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
  9. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    So that is why the exhaust is blowing!? the other studs are also equally corroded and nuts are almost gone. Far left is more or less okay, but the others are finished. I have studs and gaskets and nuts, but do I have the nuts to do the job?
  10. GU 955i
    GU 955i Member
    Apr 16, 2022
    73
    You'll sort it, the bike is lucky to have you!
  11. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Seems like ages since I last posted. But I have today taken off the exhaust after removing the two nuts that were holding on the whole exhaust! Two studs removed so far and I will work my way through the rest of them. I have a good tool, but it requires a 32mm spanner to loosen it after getting the stud out. I don't have one! At least I've made a start though. I've got the new studs, the new gaskets and will get the bike MOT'd, taxed and insured by end of May! That is my target, so I can enjoy some good weather riding etc...
  12. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Got the stud out of the tool (pipe wrench to the rescue). Have bought a mini blowtorch thing so that I can heat up the remaining studs after having sprayed them again. Have to drain radiator and remove it I think.
  13. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Studs remaining to remove.
  14. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Progress. 5 out and one recaltricant stud remaining
    The solution!! Hammer time and wind it out!!
    All out and gaskets removed as well.
  15. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    I am going to fit new copper exhaust gaskets (rocking horse poo to find but I have a full set). And I have new studs and nuts. Copper slip anyone!
    Also going to rewire the indicators with the below connectors, waterproof and with heat shrink added. Will solder them up neatly.
  16. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Exhaust wiped down. Engine case painted with high temp paint, will fit studs and think about putting exhaust back on. Need to do indicator wiring and new throttle cable, so will take the tank off and run new cable and redo indicator connections. Will take a little while, but will be worth the time.
    Replacement fan for the radiator is coming, cost me £24 delivered. The old one is rather crusty and rusty.
  17. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Studs and gaskets in and exhaust back on!
  18. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    New throttle cable installed, routed in the correct orientation. Also new O Rings on the fuel connectors and have refitted the tank. Just waiting on the fan to arrive. Need to drill out a snapped bolt, radiator one in the top part of the frame. Annoying!! May cut a groove in it and see if I can wind it out. Project for another day!
  19. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Indicators are all wired in. Front ones have the waterproof connectors. Just waiting for the fan now. Radiator loosely fitted to check connections work and to keep it safe off the garage floor.
  20. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    The replacement fan arrived today. Great condition, no rust, wiped down and installed. Just need to redo the coolant hoses and add coolant, then ready for MOT tomorrow if time permits.
