Hello - 2001 Speed Triple Owner
Discussion in 'Newbies Hangout' started by Gordon MacBean, Nov 16, 2021.
  1. Gordon MacBean
    Gordon MacBean Active Member
    Nov 16, 2021
    159
    Welling, KENT
    I've put together a short list of things to be done.
    Short term:
    Brake Fluids front and rear - Front Done
    Replace Brake and clutch levers - Done
    Fuses check - change 10A for 30A fuse - Done
    Replace Instrument Cluster back box - Done
    New engine bolts - stainless steel - Started
    Speedo Cable - Waiting for Delivery
    Clutch Cable – Waiting to change
    LED Bulbs for Headlights - Done
    LED Bulbs for Instrument Gauges – Waiting for 286 bulbs
    Oil and Filter Change – Waiting to change
    Fit Bar Risers – Waiting for Delivery of longer M10 Allan key bolts
    Replace Indicators – Waiting for Delivery
    Replace Brake reservoir – Waiting for Delivery
    Fit Fork Guards – Waiting for Delivery
    Fit Spark plugs - Waiting to change.
  2. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Forks guards now done. Cheap fix off Ebay, £10.
    LED bulbs are working nicely. Much clearer than before.
    Have also used TuneEcu (I used to use the Windows version years ago on my Sprint RS) and cleared all error codes, reset TPS and run all tests. Bike is starting on the button and running more smoothly. Warms up quickly enough and it is getting there nicely.
  3. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Fuse ratings for my Speed Triple. Just putting it here so that others can find it quickly and easily.
  4. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Bar risers fitted. New brake lines on order, going for the single line to each caliper setup, just easier to bleed as well. I had a new brake reservoir on order via Ebay, but Hermes have managed to lose the order, not the first time they have done this, so I've lost a good purchase. At least the seller has refunded the money. Have a nice big 46mm spanner for rear wheel nut. Just need to sort out fitting indicators with bullet connections to the Triumph connections. Will cut and solder the connectors I think, heat shrink etc... Will look neater and just work. But that is work for another warmer day!
  5. DanielB
    DanielB Noble Member
    Jan 13, 2019
    881
    393
    Abingdon, Oxfordshire
    I'll be eager to hear how you get on with that 46mm nut...
    I can't get one off...so all hints and tips eagerly awaited!
    What brake fluid reservoir you going to get (eventually) or just a replacement?
  6. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    I'll see how that nut shifts. The spanner is huge, so may well have enough leverage. I'm also a fairly large man at 6ft5 and 19.5 stone in weight, so I can be persuasive....
    Looking to get a normal Triumph reservoir as replacement if I have to. Will see how new brake lines go first.
  7. DanielB
    Jan 13, 2019
    881
    393
    Cool, thanks.
    I updated all the brake lines too...
    Have been considering a metal reservoir....
    Good luck, enjoy your steed!
  8. R_1000
    R_1000 Elite Member
    1,476
    700
    UK, London
    Welcome buddy :)
  9. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Fuel Connectors in the tank are the old plastic ones. One has gone "crack".
    So I have ordered the Viton ones from Tom Parkers. References below. EX VAT and Delivery which is £8.95 per order.
    cLCD100040V CPC PIPE THREAD - VALVED - MALE THREAD (THREAD SIZE: 1/4" BSPT - FUEL LINE BODY) £21.53 EACH
  10. DanielB
    Jan 13, 2019
    881
    393
    You sound far more technically proficient than me, but a heads-up on those fuel connectors, just in case.. which I also got and are great...
    The seal is not created by tightening the connectors 'home', that will damage the seal. The tightening comes from using ptfe tape and using that to give a fuel tight fixing, but not bottoming out the thread, if that makes sense.
    So, plenty of PTFE, and thread about half way in.
    I was told this directly by Tom P...after ruining a pair of connectors : unamused:
  11. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Thanks for that tip. I also have threadlocker which is a sealant in itself, but have lots of PTFE tape laying around (just need to find it).
    Always glad to have a voice of experience giving advice and real life information.
  12. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    New Clutch line now fitted, the old frayed one is out and "in the bin" to quote Marty from MightyCarMods YouTube fame! Actually, quite a few bits have ended up "in the bin"! But it is worth it in the long run to have a bike with nice components fitted that just work.
  13. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    New fuel quick release connectors here. Have to get the broken one out now somehow. It is fragmenting. Fortunately I have a tapping set, so may be able to chase it out bit by bit. Patience is the game for this one. Fuel filter will be here in a few days as well. I've got the fuel flange rubber filter arriving later on as well as the old one was a mess. Must be the original one.
  14. DanielB
    Jan 13, 2019
    881
    393
    ...could you take a few photos of getting to the fuel filter, replacing, and what bits may need replacing at the same time? It's on my list to do...and "real" photos and description of the process is always better than any manual!
  15. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Will do. Just waiting for the bits to arrive. I've done the quick release connectors now. PTFE tape was a better idea than locktite.
    Broken on is on the left.
    Metal fuel connections. Yay!
    Got the bits out and had to clean out the broken bits with a tap and die set.
    The debris removed from the thread.
    New connectors. Yes one is facing the opposite way. it is the one with longer cable and so easier to release it from that angle.
  16. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    I will chronicle the fuel filter change and the new fuel plate gasket install. All straight forward to do to be honest.
  17. Geoff Butler
    Apr 5, 2021
    626
    143
    Hampshire & Powys
    I plan to do a fuel filter change on my 1998 T595 but don't know whether to replace the short hoses too.
    Are you just replacing the fuel filter canister?
  18. DanielB
    Jan 13, 2019
    881
    393
  19. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    M
    The hoses on mine are in great condition and they are 20 years old. I'd not worry about those. The rubber fuel plate gasket is the bit that may need replacing though. At nearly £40 delivered, not cheap, but it does stop it leaking etc...
    Mahle filter should be here by Friday. It will be a 5 minute job to swap it over and then a bit longer for the 14 bolts back into the fuel plate etc... I will take photo's.
  20. Gordon MacBean
    Nov 16, 2021
    159
    Welling, KENT
    Race Brake Lines in and new reservoir installed. A bit fiddly but not leaking and firm lever. Will bleed again in a few days. Air filter was filthy. Ordered a Pipercross filter and will install that. Going to look at getting plugs sorted next as I am sure those are ancient!
