Gear Indicator
Discussion in 'Triumph General Discussion' started by Foxy, Apr 20, 2018.
  1. Mr Toad
    Mr Toad Senior Member
    Oct 14, 2016
    262
    Nottinghamshire
    stripplemont is correct.
    This line from the fleabay advert is the important bit.
    NOTE:If you motorcycle have Gear Display , you can refit,If didn't have Gear display before,need check if the engine has no reserved jacks,if has, can refit, if didn't have,can't reft.
    In other words if you're replacing a broken gear indicator then fine. Or, if you don't have a gear indicator but the bike has an interface for one then fine. But if the bike doesn't have an interface for a gear indicator you're buggered.
  2. Foxy
    Foxy Well-Known Member
    Dec 13, 2017
    116
    Sheffield
    Thanks for that, Mr Toad.
    Now for the next question........
    Does anyone know if my non ABS 2011 speed triple has the aforementioned interface?
  3. StrippleMont
    StrippleMont Senior Member
    Nov 5, 2016
    344
    220
    Round your way!
    Does your bike have a gear indicator now?
    If not the only way is a GIPro. It has the interface built into it already. It plugs into the OBD socket (On Board Diagnostics). It translates data from the ECU (gear position) and displays in the GIPro as a gear position digit. :confused:;)
  4. Foxy
    Dec 13, 2017
    116
    Sheffield
    No, it doesn't.
    Thanks for clearing that up, Strip. Not bothered about paying that sort of price. I'll keep trying to find 7th.
