Featured Daytona 900 Cafe racer project (CRK kit)
Discussion in 'Builds & Projects' started by Cafe Hinckley, Nov 14, 2016.
  1. Cafe Hinckley
    Cafe Hinckley Well-Known Member
    Nov 2, 2016
    176
    Reading
    I had a steel ramp but it was a bit short and made it very steep so embellished it a bit with the left over plywood. Was a bit sketchy but got her up unscathed! :)
  2. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Update: Another good day in the man shed yesterday (albeit a scary one) as I managed to get the wiring loom free and pull the engine ....
    I'm pretty sure its going to be a lot harder getting it back together!! :)
  3. thebiglad
    The motor looks in very tidy order :)
  4. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Hey biglad,
    Yes the engine is not bad at all and the bike in general is in very good order. Paint is flaking off by the manifolds and there must have been a bad gasket at some point as the lower section is very gunky but I will get that all sorted.
    Question: has anyone every used an engine stand for working on an engine - I am thinking this could be really usefull but not sure if it would work ...
    Any advice??
  5. Havit
    might come in handy:D:D
  6. thebiglad
    Hi CF, having seen engine stands being used on these "doing up an old dog" type programs they look really great - just can't quite imagine how you would attach the bike engine to that stand ????
  7. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    #27 Cafe Hinckley, Dec 5, 2016
    Must have sold out as I cant find it anywhere but the bike on the cover look ACE!! :)
    As for the stand - The four arms are completely adjustable and imagine I would line them up with the three mount points on one side of the engine. Not sure if that is a good idea though - it's quite a heavy lump!
    Ill see if i can get hold of Sealy and ask directly.
  8. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Just typing that made me realise how daft i was being but this seems to be a good work around...
  9. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Turns out the do a motorbike one - DOH!! :eek:
    Problem solved ...
  10. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Quick update - some family commitments this weekend so not much time to spend on the bike but i did get the engine mounted in the stand and is now ready for a good clean and service ...
    Rotate functionality works well (apart from the bit where all the remaining engine oil ran out!!)
    Live and learn :)
  11. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Christmas has come early !!!!
  12. Boothy
    Boothy Active Member
    Sep 9, 2016
    117
    Lancashire
    Looks like your in for a busy Christmas in the garage !!! :)
  13. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    I CANT WAIT!!
  14. Boothy
    Sep 9, 2016
    117
    Lancashire
    Wonder if you can help me out, did your Daytona come with a water pipe cover over the water pump hoses ? if so could you send me a photo or 2 of how the brackets locate that hold the cover as j want to fit one to mine. i know there is a threaded fixing off the water hose do not know how the lower fixing bolt locates
    Thank Paul
  15. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Hi Paul,
    Yes indeed i did have the cover and although i have removed it i believe the brackets are still in place so will take a pic and send it over this eve.
    Cheers
    Jonathan
  16. Boothy
    Sep 9, 2016
    117
    Lancashire
  17. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Hi Paul,
    here you go ...
    The shield mounts at the two points i am pointing to:
    the top mount point is actually part of the feeder pipe and the bottom point uses a bracket
    Here is how the mount locates:
    You may need to get the daytona pipe to supply the top mount.
    Cheers
    Jonathan
  18. Boothy
    Sep 9, 2016
    117
    Lancashire
    cheers thanks for that, will have to get the pipe and lower bracket
  19. Cafe Hinckley
    Nov 2, 2016
    176
    Reading
    Tis the season to be cutting - fa la la la la la la la laaaaaaa ....
    No going back now!
  20. Jennoe
    Jennoe Active Member
    Nov 17, 2016
    76
    Newport Sth Wales
    For what you are about to receive...May the Lord make you truly thankful..............
