Chain Replacement
Discussion in 'Technical Help' started by Graeme Copland, Jan 1, 2019.
  1. DanielB
    DanielB Noble Member
    Jan 13, 2019
    881
    393
    Abingdon, Oxfordshire
    2002 955efi.
    In blue - the best colour.
  2. freck
    freck Elite Member
    May 4, 2017
    1,718
    Preston, Lancs, UK
    What model though? The 955 engine was used in a variety of bikes
  3. DanielB
    Jan 13, 2019
    881
    393
    Oh, sorry... Speed Triple.
  4. DanielB
    Jan 13, 2019
    881
    393
    I've done some counting and I'm 17/43...
    If I play around with this teeth combination for a more relaxed ride, so 18/42...does this effect other things, like needing a remap or anything...or ...
  5. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    No remap needed, but I have got TuneECU if you want to calibrate the MPH to a new sprocket ratio, as a change up or down would indicate a higher/lower speed than actual
  6. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    Offer still open if you want a hand swapping out sprockets and chain (and ECU MPH adjustment), I can even balance your wheel for you:)
  7. DanielB
    Jan 13, 2019
    881
    393
    Hi red thunder, thanks for this...I'll pm you.
    Out of interest though, isn't the 2002 955 efi a mechanical speedo cable...and just measures the rotation...?
    What would need recalibration?
  8. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    Urm, yes. Yes it is mechanical:neutral:
  9. DanielB
    Jan 13, 2019
    881
    393
    Erm... Are you sure it's a good idea that you show me what to do:scream:
  10. Red Thunder
    Dec 2, 2014
    2,034
    High Wycombe
    As you had mentioned remapping I was thinking ECU fuel maps and mph calibration...not needed if it is mechanical...my bad
