Carb Mixture Screw Settings On A 790cc Bonnie With Tor's Anyone?
Discussion in 'Bonneville' started by MartyWilson, Sep 7, 2020.
  1. MartyWilson
    MartyWilson Guest
    Hi @Wire-Wheels having been doing a little learnin' as to carb operation I agree with you on the pilot jets. On my other bike the bike's history says that the mixture screws had been turned out to four turns and then the pilot jets were changed from 40's to 42's and the screws then turned back to three turns so this would agree with what you say and what my own research has indicated to be the solution. I am waiting for some new 42 Pilot jets to arrive in the post and then I will be whipping the carbs off, cleaning them and putting the bigger pilot jets in. On the other issue of high speed problems that's not mine but rather @Ben1307 's problem. Both my 2001 Bonnie's have easily achieved an indicated 110mph on the clocks with some throttle left and, if anything I have a lot more power available in the higher rev ranges than I do in the lower ones and no signs of problems in except in the rev range where the Pilot jets have a part to play.
  2. steve lovatt
    ...and this is why we have electronic fuel injection!
    :joy::joy::joy:
    Had a lovely 2004 790cc T100, which ran beautifully. Fitted Dunstall TOGA exhausts, still good. Fitted 115 main jets to compensate for potential leaness. (Apparently in the early years some dealers would swap out the stock 110s for 115s). After fitting a bell mouth and free flow filter I started messing with needles and shims. Never ran as well again! :mad:
  3. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    All good points, and yep....I don’t much above 80 at all.
  4. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Ah....the bogging occurs for sure in 4th and 5th....starting and idling are fine. A curious thing though is since last week, the popping of the exhausts has just stopped. im going to go through the jerks guide very carefully....and it’s off with the carbs again.
  5. MartyWilson
    MartyWilson Guest
    I have to say that returning these bikes to 'standard' does seem rather tempting as the 'tuning' seems to be more hassle than it's worth on bikes which don't really need any more than the power and top speed that they were born with. The only thing that would be hard to have to lose is that glorious sound from the open exhausts.
  6. Wire-Wheels
    Wire-Wheels Elite Member
    Apr 26, 2019
    2,497
    California - USA
    The farther you deviate from stock, the more the bike becomes your own creation. The more you deviate from the factory creation, the more you have to assume the role of engineer. :) ...J.D.
  7. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Too right on all counts. ☹️
  8. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Ain’t that the truth.
  9. Wire-Wheels
    Apr 26, 2019
    2,497
    California - USA
    Take it from an old man who has been doing this since he was about 12yrs. old. You can tweek yourself in to a corner. At times I come up with ideas, but then think "if I DO that, then I really should change that, and that and... Do I want.to go there?."..You need to know your limitations. It is like me with music. I play the radio. I do not have the dna to make the music. ...J.D.
  10. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Those are wise words indeed. I come late to the party having always let things be and given my bike to be serviced at garages. Now retired I have the time to look over the bike closely and thus picked up first the pilot screw bodge and then upon recommendation fitted the 115s. I’m beginning to regret it. Upon close inspection today I also find the seal between air box and LH hose (the catalogue calls it a ‘runner’) to the carb is not tight all the way around. Not helped of course by recent twice removal of carbs. A visit to a dyno test centre beckons.
  11. MadMrB
    MadMrB Elite Member
    Dec 24, 2018
    3,562
    Northamptonshire, UK
    The standard silencers on the Bonneville are awful, too heavy and too restrictive, when I replaced mine the bike felt like it had just lost a ball and chain. I didn't notice any difference from replacing the main jets, but that I think was just me being over cautious and wanting to make changes in small increments, I have larger jets that I plan to experiment with and install over the winter. Changing to a K&N filter also did not make any noticable difference, but getting rid of the snorkle and fitting a bellmouth made a very noticable difference, not necessarily to increased performance but to smoother running and especially noticable on cold start up.
    All the changes I have made to my Bonneville were made bit by bit, first silencers, followed by filter, AIS removal, then jets & carb setup, finally snorkle & bellmouth. I'm happy with the way my bike rides and performs, but I'm sure in the hands of someone who knew what they were doing it could be greatly improved.
  12. Callumity
    3,358
    Exactly. One thing at a time unless you have an exhaust gas analyser. My 865 ran markedly better after opening inlet and exhaust and most combinations have been tried and documented so there is really not much guesswork involved. However, creating air leaks etc., isn’t going to help!
  13. MartyWilson
    MartyWilson Guest
    #33 MartyWilson, Sep 15, 2020
    Ah there is a significant point about yours @MadMrB .... You did them, starting from 'stock' and moving forwards so you know what has been done and can, if neccessary, undo it. I am in the position of not knowing what has been done to this particular bike internally, only the obvious things I can see externally. I also do not know if the modifications were made properly and everything done right. Certainly I have discovered on this machine that externally everything has been tightened up by a gorilla, hence the snapped mirror stalk bolt you helped me out with amongst other things.
    I guess part of the challenge of motorcycles, which is coming back to me in spades at the moment is the 'joy' of having to sort problems out and undo what has previously been done by others. While I have been fiddling with my most recent 2001's running problems the battery on my other one seems to have packed up after the first ride out with the lights on.
  14. Callumity
    3,358
    Well you can’t really avoid unscrewing the float bowls and seeing what is in there. The thing to remember is that nothing will work as it should if the carbs are not clean. Garage queens get progressively more furred up with fuel residue. I spent £90 on an ultrasonic bath and £10 on cleaning additive that got crap out I didn’t know was in there...... they also came out shiny on the outside in all the nooks and crannies. TTP supplied the right jets for my silencers and inlet mods and all I had to do was tweak the air screw a quarter turn to minimise popping on the overrun.
  15. Wire-Wheels
    Apr 26, 2019
    2,497
    California - USA
    #35 Wire-Wheels, Sep 15, 2020
    The point of doing one thing at a time is a good one. That being said, one thing usually leads to another. My 790 came to me already set up with a pair of Stayintune pipes. I assume it has had some jet work. The airbox is stock. I have just left that one alone because it runs great. One of the previous owners did a good job. On my other 2 Triumphs I have delved deep in to tuning. Pipes, jets, changes on needle heights, chopped airboxes, etc. Depends on how far you want to take it.
    ...J.D.
  16. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Ah, I understand changing the filter, jets and carb set up, even removing the snorkel and bell mouth. But, the AIS removal...I’ll have to google it. How easy was it?
  17. Ben1307
    Ben1307 New Member
    Aug 22, 2020
    Just watched Delboys video on AIS removal....looks easy.
  18. Hobnail
    Hobnail Senior Member
    Jan 4, 2020
    1,245
    USA
    It's all what you consider enjoyment. I turned the idle screws out 1/4 turn from stock and greatly reduced the popping on overrun and it helped low throttle surging. Cold start up is still a bit touch and go, and I may get the vacuum gauge out to troubleshoot. Or maybe replace ignition coils. I guess I am a tinkerer at heart.
  19. Wire-Wheels
    Apr 26, 2019
    2,497
    California - USA
    Gearhead to the bone myself. Spent my whole life with mechanical things. Never was much good at anything else :D. ...J.D.
