2018 Scrambler Oil Pressure Light Stays On But Engine Is Fine (help)
Discussion in 'Technical Help' started by Werner Botes, Feb 5, 2019.
  1. Eldon
    Eldon Elite Member
    Oil pressure going down as the oil warms up is perfectly normal. This is due to the viscosity change against temperature I.e. the oil becomes less viscous.
    Revving the motor will bring it up to the relief valve setting which will then bypass capping the oil pressure at the set value. I don't have the specs. for this motor but the figures don't sound bad or ring alarm bells :p
    Do you have a wiring diagram for the oil light circuit?
  2. Werner Botes
    Werner Botes New Member
    Feb 5, 2019
    7
    South Africa
    Thanks Eldon, that is how I understand it too. And NO I dont have a wiring diagram, but sure google is hiding one somewhere
  3. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    I have been searching for manuals for a while but have turned up nothing unless you buy a manual.
    Oil pressure is about average for most modern engines that use a relatively low weight multigrade oil, 10 to 15psi is about the minimum you want to see at idle when hot, and anything from that to 60-80psi at WOT the PRV will be set to around 90-100psi which with cold oil it will easily see,
    I am now very curious to see a manual as the comment on that link the guy is saying that there are two oil pumps one for oil pressure and one for cooling i am a little skeptical about this as it seems a very overcomplicated setup when one oil pump would easily achieve both ...and does so on a lot of car engines.
  4. Ken walburn
    Ken walburn Noble Member
    Jun 28, 2017
    889
    Good new, defo not engine oil starvation. Good news you have a great mate. Dash should fix it then, unless you’ve missed a wire going to earth/ground from switch to dash. Good luck. oh by the way most/all of the guys & girls on here like a Happy Ending o_O
  5. phillmore
    phillmore New Member
    Feb 12, 2019
    worcester uk
    The double oil and cooling pump is a combined oil and water pump.
  6. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Have you any links to a schematic of that? as its supposed to be a solely oil cooled motor no water cooling on that model which is why i am skeptical of any need to run two separate pumps for oil.
  7. Yorkshireman
    What!!
  8. Yorkshireman
    It’s a liquid cooled engine with one oil pump,one water pump, both systems operate independently of each other.
  9. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
