wtd: rear brake disk for steamer
Discussion in 'Wanted' started by ram33, Feb 27, 2014.
  1. ram33
    ram33 New Member
    Oct 21, 2013
    4
    in the middle of rebuilding my bike and noticed the rear disk has at least 2 cracks :frown:
    would anyone have a decent brake disk for steamer? maybe someone upgraded their wheels?
    im in uk (near derby / notts)
    if you can help please pm me
    looked around and found a new copy one for £70 which will have to do otherwise
  2. SteveJ
    SteveJ Super Moderator
    Aug 12, 2013
    524
    North Hampshire
    What bike ram??
    BTW if the these new discs come from China I suggest you stay well clear.
    Cheers
    Steve
  3. ram33
    ram33 New Member
    Oct 21, 2013
    4
    its a triumph tiger 885 carb model (steamer)
    not sure where the discs are from, i saw it on ebay
  4. SteveJ
    Aug 12, 2013
    524
    North Hampshire
    Ram I would check to see if those Discs are coming from China on E Bay as I have heard that they are about as much use as milk bottle tops.
    A lot of the older Hinckley parts were interchangeable so have a look at this thread and call Rod or Ivan and they may be able to help, there is also Triumphaunt in Wales that may be able to help.
    http://thetriumphforum.co.uk/forum/f22/parts-finder-used-parts-1540/
    Cheers
    Steve
  5. ram33
    ram33 New Member
    Oct 21, 2013
    4
    thanks for the reply steve
    i have already looked into another model using the same disc but apparently the tiger is the only one.
    ill see if a good used one is offered, if not ill give those in your link a try
