why does my bike sound like a printer when i turn the key on?
Discussion in 'Technical Help' started by Machete, Nov 8, 2014.
  1. Machete
    Machete New Member
    this may be because this is my first triumph but my bike sounds like a printer when i start it up it whirs and cliicks like a computer, any insight would be appreciated.
  2. What bike ?
    Is it fuel injected ? if it is, it's more than likely just the EFI sysytem priming itself before you fire it up.
    If it's not fuel injected, try adding more paper :upyeah:
  3. Richard H
    Richard H Noble Member
    Oct 26, 2012
    1,132
    Yep all the fuel injected bikes sound a little like an old style modem, just the fuel system priming.
  4. Machete
    Machete New Member
    2004 daytona 600 , yes its fuel injected ,so if the fuel system is priming then the fuel pump should beworking ? cause i am having trouble getting the bike to stay running . i just bought the bike for 1400 bucks and at first i thought it was a relay so i changed it but still no go .it will start up with some ether butthen it dies right away,. so i pulled the fuel pump and put direct power and it worked but when i put it back on the bike it didnt, my next step was to hook adirect switch to it any ideas?
  5. Spudda
    Spudda Member
    May 2, 2012
    32
    6
    Penn, Nr Wolverhampton
    Has the tank been off ??? the fuel hose has a habit of being kinked when the tank is put back on and therefore no fuel can get through
