Turn Signal Issues
Discussion in 'Bonneville' started by Lyles124, Oct 20, 2019.
  1. Lyles124
    Lyles124 New Member
    Mar 1, 2019
    24
    USA
    2006 America turn signal problems. Left side handlebar bulb wasn’t working. Changed bulb out and then tried again, then all turn signals didn’t work. Checked fuse, it was blown so I changed fuse and tired again. Blew fuse again. Checked wiring behind the bulb in the housing, everything seems fine.
    Any thoughts or suggestions?
    thank you!
  2. Lyles124
    Lyles124 New Member
    Mar 1, 2019
    24
    USA
    Thanks for the quick response. I went and got a new bulb and more fuses. Turns out the ground tab in the housing was somehow bent up and making contact with the power tab. Bent it back down and everything went back to normal.
