Triumph Speed 400,125 Miles, Low Oil Pressure
Discussion in 'Technical Help' started by Bob Bobberson, Apr 13, 2025 at 7:55 PM.
  1. Bob Bobberson
    Bob Bobberson New Member
    Sunday
    Albuquerque, NM
    #1 Bob Bobberson, Apr 13, 2025 at 7:55 PM
    2024 Triumph Speed 400
    Hello!
    Just starting riding and I'm absolutely loving this bike! I was out for a ride the other day when I stopped in a parking lot, put the bike in neutral, and in no less than a minute of idling the low oil pressure light came on and the engine shut itself off (bike stayed on). I decided to let it cool off for a few minutes before running it again, it started up just fine, the low oil pressure light turned off like it normally should after taking off, and made it home without any issues. When I got home I pulled into the driveway, stopped and put the bike in neutral, and as I'm reaching for the kill switch the same thing happens, the low pressure oil light came on, and seconds later engine stopped itself.
    Contacted my local service center and I'll have it looked at soon. I've been cautious about not exceeding 6500rpm when breaking it in, and haven't been riding aggressively. Checked all the fluids, seem to be at reasonable levels and no leakage on the ground when parked overnight. I'm thinking it might just be a faulty sensor, or something to do with the computer learning new low oil pressures as the tolerances within the engine loosen over the break in period.
    Any help, advise, or tips is greatly appreciated, thanks!
  2. Mrs Visor
    Mrs Visor Elite Member
    Just from anecdotal evidence from speaking to a former owner, I think it's fairly common that there is a fault with the oil pressure sensor - a quick Google seems to yield similar stories. I'd not ride it until your dealer looks at it, especially if it's going in soon anyway.
    ps welcome to the forum.
  3. MightyBoosh
    MightyBoosh Senior Member
    Mar 29, 2023
    262
    Did you leave it on the kickstand while idling? Not uncommon to cause oil starvation when a vehicle is idling and not upright. My old Astra estate would chunter along parked halfway on the pavement, then all at once start clattering! :laughing:
  4. Bob Bobberson
    Sunday
    Albuquerque, NM
    Thank you!
  5. Bob Bobberson
    Sunday
    Albuquerque, NM
    That's a good point, I'll keep that in mind. I do believe the ground was fairly level, more so in my driveway, and my kickstand was up.
  6. Pegscraper
    Pegscraper Elite Member
    Jun 12, 2020
    3,422
    Really! Assuming sensor/electrical integrity, if the OP light comes on when idling on the side stand, either the oil level is way too low or the main bearings are knackered. Running with low oil is inexcusable and anyone who does deserves a wrecked engine as a lesson.
    In the case of the 400 in this thread my money's on a dodgy sensor or wiring/connector.
    Never heard of an ECU "learning new oil pressures" either.
  7. ajc400
    ajc400 Senior Member
    Jun 4, 2024
    512
    143
    Glasgow
    Sorry to ask this - it was the oil light and not the engine management light?
    The 400's have a problem with the engine light coming on for no reason which I don't think has been solved yet. Software updates have not always fixed this, although it did on mine..... while I still had it anyway.
    I had a minor bump and sold it! :rolleyes:
  8. Bob Bobberson
    Sunday
    Albuquerque, NM
    Yes, it was the low oil pressure light. Taking it in tomorrow, I'll be sure to post what they tell me.
  9. MightyBoosh
    Mar 29, 2023
    262
    I think what happens, certainly with my old car, was the oil pickup being to one side, so when the engine fires oil around, it doesn't return quickly enough to keep scavenging. My T140 was the opposite, left pot used to start smoking...
