Triumph Bobber 2017 Traction Control Light!
Discussion in 'Technical Help' started by sajid khan, Feb 3, 2020.
  1. sajid khan
    sajid khan New Member
    Jan 11, 2020
    11
    London
    I have an issue with the TC light on my bobber (and engine light on).
    I now have minimal power as it seems like there's an electrical override.
    Any help. Please!
  2. Sprinter
    Are you still in warranty?
  3. sajid khan
    Jan 11, 2020
    11
    London
    No... Just ran out
  4. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Could be as simple as an ABS sensor gone down.
  5. Ducatitotriumph
    Apr 25, 2019
    2,181
    Rothwell
    sounds like it. Might be best to clean up the tc sensor ends (on the wheel ends) and try again. Also, if the wheel has been out, check the spacers are installed as it has to be a set distance to the rings on the wheels.
  6. Wishbone
    Wishbone First Class Member
    Nov 4, 2018
    865
    643
    Essex UK
    You haven't recently had new tyre/s?
    abs sensor/ spacing is most likely if not.
