Triumph 1050 Speed Triple Suspension upgrade.
Discussion in 'Technical Help' started by Iain Ballantine, Aug 10, 2016.
  1. Iain Ballantine
    Iain Ballantine New Member
    Aug 9, 2016
    Gibraltar
    #1 Iain Ballantine, Aug 10, 2016
    Hi all I own a Triumph Speed Triple 1050 year 2008. It is a great bike but I would like to upgrade the suspension on it. And was wondering if the Ohlins front forks from a 2014 Speed Triple R would slip strait on or would I have to do some modification. Any advise would be very much appreciated. Thanks
  2. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    I have the 2010 Speed Triple and I upgraded the front forks
    I had K-Tech springs and piston sets put in and a complete overhaul of bushes and seals.
    Looking back I didn't need the piston sets as the biggest improvement was the springs.
    You may find that sliding a set of Ohlins in may not improve the handling if the springs are not right for you.
    I would recommend a complete front fork service and have the correct springs put in that are right for you, or if you are set on a pair of Ohliin then make sure the springs are right.
  3. t552
    t552 Senior Member
    Nov 17, 2014
    417
    Bristol UK
    When we were racing (jack Lilley team) We ALWAYS used Maxton, and I have Maxton on my Trident 900. So that would be my recommendation unless you are looking for the bling factor.
