Triple Speed Starts Fine But Then Floods As Warms Up..?
Discussion in 'Technical Help' started by Roy, Dec 21, 2018.
  1. Roy
    Roy New Member
    Dec 16, 2018
    6
    Erskine
    Hi all, my Speed Triple 09 starts up no problem then as it warms up it sounds like it's flooding & cuts out..any advice would be appreciated thanks.
  2. Arno triple
    Arno triple Senior Member
    Aug 26, 2018
    613
    Uhm... check your O2 sensor? Might be related to choke. When engine is warm, choke remains and engine gets not enough air so cuts out.
  3. Wishbone
    Wishbone First Class Member
    Nov 4, 2018
    865
    643
    Essex UK
    Can you smell neat fuel at exhaust? pull a plug and see if wet with petrol.
    It could be an injector stuck open?
    also disconnect battery to reset ECU?
  4. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    With EFI water cooled engines the most common cause of bad hot start and bad/over rich hot running is usually down to a bad ECU coolant temp sensor,
    the ECU will run a permanent rich/start condition fuel mix until the sensor is replaced.
  5. Arno triple
    Aug 26, 2018
    613
    Any results Roy?
  6. Roy
    Roy New Member
    Dec 16, 2018
    6
    Erskine
    Hi everyone, thank you for your valuable advice. Im just back from travelling and going to get my bike back after being stored at friend, will let you know how I get on. Cheers again.
  7. Roy
    Roy New Member
    Dec 16, 2018
    6
    Erskine
    Update...disconnected battery to reset ECM, that made no change...still pluttering after start up & cutting out. Look at sensors next
  8. Danimal
    Danimal Well-Known Member
    Sep 9, 2018
    230
    Usa
    So many things it could be. Start with the easiest and work from there.
    Battery make sure you connections are tight and clean
    Check that your ground is good
    Wires can get pinched and break at the headstock on the right side
    There’s a vacuum hose that attaches underneath the air box on the left side that can come loose
    To check for other vacuum leaks you can spray wd-40 around the manifold. If it revs higher you have a leak
    Check the header bolts, they can loosen
    Do a 12 minute tune. Start the bike don’t touch the throttle and after the fan comes on let it idle for 12 minutes and turn it off. Then start it back up and see if that helped.
    The spark plug wells are also prone to getting wet and getting corrosion down them, so check your plugs for rust. If you find it replace them and your boots and read the plugs while you’re at it
    Could also be a fuel pressure issue, I had one that drove me crazy. Turned out to be the hoses in the tank were cracked, but fuel filter can cause trouble too. If you use tuneecu hook it up and reset the tps.
    That’s all I’ve got for simple problems, anything else will be more extensive.
