Tiger Tr7t Replacement Sump Oil Pipe
Discussion in 'Technical Help' started by JonL, Apr 26, 2019.
  1. JonL
    JonL New Member
    Feb 3, 2018
    7
    East Sussex
    Hi
    I've a 1981 Triumph Tiger Trail 750cc
    I've just notice a small (pin sized) hole in the rubber oil pipe that comes out from the sump plate - I think the engine is the same as the T120\T140. I'm not sure if this is just a standard piece of flexible oil pipe and will be ok for replacing it with the same as it looks shaped with a couple of bends in it.
    Does anyone know if\where I can get a aftermarket one, or should I just go with a bit of standard hose?
    kind regards
    Jon
  2. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Just use std oil resistant rubber hose.
  3. mpllineman
    mpllineman First Class Member
    Feb 12, 2018
    826
    Pearl,Ms.
    I would just get a piece of standard hose also, unless you just want to spend about 3 times as much!
  4. JonL
    JonL New Member
    Feb 3, 2018
    7
    East Sussex
    Thanks very much
    Do you know if the pipe has a 3/8 inch (9.5mm) internal diameter? I've measured the outside to be about 16mm but wanted to get the replacement hose before I remove the damaged one. I think oil pipes of that size come with either an 8mm or 10mm ID.
    thanks very much in advance
  5. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    From memory feed is usually 5/16 and return is 3/8.
  6. joe mc donald
    JonL
    Welcome to the Family. Picture of this steed would surely go down a treat.
    Ride Safe & Enjoy
  7. Tricky-Dicky
    Dec 12, 2016
    2,441
    Norfolk UK
    Just to add i am pretty sure i used 8 and 10mm on my T160.
