Tiger Sport Front Brake Pads
Discussion in 'Technical Help' started by Nick Grey, Jun 4, 2018.
  1. Nick Grey
    Nick Grey New Member
    Jun 3, 2018
    5
    Hullbridge
    I plan to change the front brake pads on my 2015 Tiger sport 1050. Anyone know of any difficulties or problems I may come across?
  2. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    Thanks for the tip
  3. topdec
    topdec Member
    May 30, 2018
    Farmington Minnesota
    Sometimes I forget and pull the brake lever while the pads are off...don't do this.
  4. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    Thanks for the great advice
    I have ordered the pads and will be back if I have a problem
  5. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
  6. chuk
    chuk Senior Member
    349
    neilston glasgow
    if the Allen key starts to slip in pins after a dose of penetrating fluid,you may be able to grip pin along its length using good quality mole grips or similar to get movement.
  7. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    Thanks
    this is brilliant information. I will be in touch if I have any problems. Waiting for pads to arrive.
  8. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    My experience is that I have done it loads of times on a car. I am hoping it will be the same. I will be in touch if not.
    Thanks for your help
  9. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    I would say my Mechanical skills are around the the 7 = 8 nark but I often find I don't have the right tool.
    My experience is that I have done this loads of times on a car. I am hoping it will be the same. I will be in touch if not.
  10. steve lovatt
    Good advice from DD - I rounded off the hex head on one off the pins on my T100 and had to drill it out and the same with my SE on the rear. It is a right royal pain in the arse! o_O
  11. Nick Grey
    Jun 3, 2018
    5
    Hullbridge
    Pads all done , no drama really was quite easy. Thanks for all the help and comments
