Tec Bike Parts Monza Fuel Cap.
Discussion in 'Bonneville' started by macamxthe1st, Jul 11, 2018.
  1. macamxthe1st
    macamxthe1st Well-Known Member
    Just fitted a Tec Bike Parts Monza Cap. Once the cap and adaptor screwed in I had to back off the cap by nearly 3/4 of a turn in order to align the cap. This feels like an awful lot a I would have thought compromise the adaptor/tank interface seal. Has anyone else fitted one and if so did they encounter anything similar.
    Geoff.
  2. crispey
    #2 crispey, Jul 11, 2018
    Is there a seperate threaded collar that goes inside the tank neck the cap screws on to that??
    if so you have to line position of the inner threaded collar and the cap right
    take a look at the 3rd post from the top here
    if so beware the fine thread...its a finger stripper
  3. StrippleMont
    StrippleMont Senior Member
    Nov 5, 2016
    344
    220
    Round your way!
    Sounds like the usual crap standards for TeC stuff;)
    I'd send it back for a refund, don't want leaking fuel on any bike!
  4. BykerBry
    BykerBry Well-Known Member
    Aug 8, 2017
    104
    Reading, Berkshire
    My experience of Tec parts is not good either so I tend to agree. Phone them first though and see if they have an answer to your problem.
  5. macamxthe1st
    Just had a good second look at it and as I suspected the adaptor/tank seal is badly compromised. I have removed it and will speak with them tomorrow, I do suspect however that I will be making a trip to the post office.
    Geoff.
  6. crispey
    looking at the tec website it looks like a 2 part one like mine, the cap screws off the bit that screws into the tank, so you should be able to get it to line up
  7. macamxthe1st
    Unfortunately, it appears not to be so. the amount that I have had to back it of to achieve the correct orientation has resulted in about 1/8th of an inch separation of the sealing faces. I will reserve judgement in case I have done something stupid (not for the first time) but if this is indeed the case then itis not at all acceptable.
    Geoff.
  8. crispey
    Did you get the £60 or £30 one? The £30 doesn’t come woth an adapter but the £60 one does
  9. StrippleMont
    Nov 5, 2016
    344
    220
    Round your way!
    So the £60 fits..... and the £30 does'nt (bin job):D:D:D
  10. macamxthe1st
  11. macamxthe1st
  12. StrippleMont
    Nov 5, 2016
    344
    220
    Round your way!
    So you bought bought the £60 that should fit .... but doesn't??
    Aren't TeC great:D:D
  13. crispey
    Ok so you’ve got 2 parts the cap and the threaded adapter that goes into the tank? Did you get a couple of large cork Washers? These are spacers of different thickness. That go between the cap and the tank I used only one of them to line it up right. Mine were taped to the outside of the box. If you didn’t get any you could make your own and experiment. Or try screwing it in a 1/4 of a turn further back
  14. macamxthe1st
    Got a very prompt reply from George Milburn of Tec Bike Parts. I am as I feared being a tad stupid. The cap is designed to be orientated as per the Thruxton fitment with the hinge to the rear of the tank. I checked this on the Triumph Web site and this is indeed the case. In this orientation, the fit is quite acceptable. Thanks for all the input.
    Geoff.
  15. John T
    John T Senior Member
    Jun 4, 2015
    613
    Newcastle upon Tyne
    Pleased to hear you got sorted my experience with TEC has been good but there are a few who dont share the majorities opinion...still its a free country (ish)
  16. StrippleMont
    Nov 5, 2016
    344
    220
    Round your way!
    Certainly sounds a lot better than my experience!
    "Like it or lump it" comes to mind!
    As you say, everyone has an opinion!:p
  17. mpllineman
    mpllineman First Class Member
    Feb 12, 2018
    826
    Pearl,Ms.
    Don't let it bother you too much, we've all been there and done that. I will even venture to say that I will be there again soon. It's just being human! Glad you have that sorted.
  18. bernard j czech
    Jan 17, 2020
    70
    coal township Pa
    looks like a Monotone Monza cap is the way to go!!
  19. beerkat
    beerkat Senior Member
    Aug 14, 2019
    859
    Cheshire UK
    I started with a TEC Monza cap (which has a grub screw locking thingamyjig) but still couldn’t get it to line up how l wanted and give a secure seal, so it went in the ‘not sure what to do with’ drawer.
    I then went for a Motone straightforward screw on billet cap (in black). Looks great.
    Btw l’ve had several TEC parts and have generally been impressed with the quality, considering their price. You get what you pay and all that jazz.
