Taillight Options For More Rear Visibility
Discussion in 'Bonneville' started by Traveler, Feb 14, 2024.
  1. Traveler
    Traveler Well-Known Member
    Jun 21, 2023
    144
    Helena, Sweet Home Alabama
    Wife was following me to drop-off the Bonneville at the shop yesterday. First words outta her mouth when we got there was "You need more lights on the back of that thing - they are hardly visible", She's a former rider herself and realizes the importance of being 'visible'.
    Any suggestions as to where to start looking?
    Tks!
  2. FezUSA
    FezUSA Member
    Sep 1, 2023
    38
    OH, USA
    Look at Admore Lighting - I have their light bar attached to the top of my license plate. Provides running light, flash > solid brake light (with decelerometer sensor), progressive amber turn signals, and a license plate light in case the bar covers the stock one. I have a number of their products and can tell you that while they're not going to be your cheapest option, they make high quality stuff that will hold up to the rigours of the m/c environment!
    Denali also make good stuff. They have a number of options available. Again, not cheap but very good stuff.
  3. Traveler
    Jun 21, 2023
    144
    #3 Traveler, Feb 15, 2024
    Thank you. Will check those out!
    Any problems with wiring it; or should I ask any problems after wiring it into the stock circuits?
  4. FezUSA
    FezUSA Member
    Sep 1, 2023
    38
    OH, USA
    Nope. They provide appropriately sized Posi-Taps so you get solid and waterproof connections. You have to figure out cable routing and where to tap in to. I use a power distribution module (Healtech Thunderbox is my choice, but there are others out there) which provides me with positive and negative once the engine is running. For my TS660, the rear indicators are red with dual functionality - brake and turn. So I tapped into the L/R wires that go through the OEM tail tidy to my stock turn signals. I also routed the light bar cable through the tail tidy and only had to drill a small hole in it.
    Note I have two wires going in to the back of each Posi-Tap as I have both a rear light bar as well as vertical LED strips in my panniers. I'll be adding a 3rd set of wires when my top box gets the LED treatment
    Close up of the Posi-Taps. The wires at the top/back are the ones from the accessory (light bar and light strips in this case), the other end of them attaches to the wire you're connecting to.
    Drilled a hole in the tail tidy to route the light bar cable. There was a 3rd circle marked which is where I drilled through.
    Cable from light bar to tail tidy
    Running light
    Brake light
    Screen cap from a clip of progressive amber turn signal. You can see the pannier led strip is brighter on the left, it is on/off while turn signal is activated. The light bar is bright amber with a center to outside progression.
  5. WhiteHeat
    WhiteHeat New Member
    Jan 7, 2023
    Dorchester
    Denali make fabulously bright lights (as well as horns that get you noticed!). I have them on my GS, but not yet on my Triumph Speed Twin. Their rear lights for the Triumph are generic, but they make an LED replacement headlight unit that looks awesome.
