T140v Oil Filter Conversion
Discussion in 'Newbies Hangout' started by uselesstony, Dec 9, 2017.
  1. uselesstony
    uselesstony New Member
    Dec 9, 2017
    France
    Hello. I have a 1976 T140v. I've seen the oil filter conversion kits with the external filter cartridge.
    Are they very difficult to install and are they in fact any use ?
    Thanks for your helps mates; T
  2. Tucker 1963
    Hi welcome to the nut house you should fit right in.Someone will be along shortly that can help you.
    Tucker:mask:
  3. dilligaf
  4. stevethegoolie
    stevethegoolie Elite Member
    Oct 16, 2014
    2,454
    East Riding of Yorkshire
    Hi, Tony.
    External oil filter is an excellent upgrade - more oil in the system and it's cleaner too!:cool:
    Don't know how easy they are to weld, Araldite, superglue, nail, screw or tie on 'cos I've never done it, but I would guess that there are some external oil lines to tap into near where the filter is to be located.
    Oil filtration on these bikes is (I believe) by way of a flywheel sludge trap -very basic:rolleyes:, which when it gets full is of little use: unamused:. Modern oils usually contain detergents which will clean it out eventually, but may also cause the engine to die a sudden, painful death due to bits of muck blocking up vital oilways - think blood clots causing a heart attack/stroke (I had one of them once - not fun!) and you'll be not far off.:eek:
    If in doubt, have a word with people who supply the kit, and better still, with anyone who has fitted one or had one fitted.
  5. darkman
  6. MickP
    MickP New Member
    Jun 19, 2018
    Worthing
    Hi Tony
    I'm planning to do a similar thing to my T140e.
    I have been looking at Paul Goffs modification which seems to be highly thought of...
    Did you fit yours in the end.
    Mick
  7. Wessa
    Hi and welcome.....
  8. R_1000
    R_1000 Elite Member
    1,476
    700
    UK, London
    Welcome buddy :)
  9. Helmut Visor
    Hi Tony, and welcome in :cool::cool:
  10. Tiglet
    Hello Tony and welcome to the forum :)
