T120 Engine Bar Installation.
Discussion in 'Builds & Projects' started by Name, May 31, 2019.
  1. Name
    Name Member
    May 23, 2019
    25
    Omaha Nebraska
    Wasnt able to find any threads on this and curious if anyone had installed their own engine bars. I'm on the 2018 t120 and my first concern is that it's attaching to the same bolts as are mounting the engine to the frame. Obviously there would be no need to remove all at once, but i don't want tti run into any problems with it shifting even if i do one side at a time. Anyone done this?
  2. Dale
    Dale Member
    Feb 12, 2018
    49
    Cincinnati
    Hey there, it's been awhile & you may have already decided but I mounted mine in the garage. The kit supplies new bolts to be torqued @ 72 lbs if I remember. The directions tell you. Don't re-use these bolts. I'll be installing a sidecar on my t120 & already have new bolts to use after taking the right side engine guard off.
