Street Twin Fuel Tank Lock
Discussion in 'Technical Help' started by James597, Feb 3, 2020.
  1. James597
    James597 New Member
    Sep 30, 2019
    4
    Greece
    Hi there. I realised a couple of days ago that I can open the fuel tank without the key. My question is: do I need a new fuel tank cap or is this a common issue?
  2. Notso
    Notso Senior Member
    Dec 17, 2018
    634
    Solihull
    I guess at least your issue doesn't leave you stranded unable to fill up. Did you tighten to one click before locking? Assuming it all appears to work properly when not in the tank.
    I bought the black aluminium billet one that doesn't lock, as I think it looks better, less to go wrong and is less faf! I suppose someone could nick the cap or fuel, but they could take loads of other bits that are more valuable as well if they want to.
  3. Samsgrandad
    Samsgrandad Senior Member
    Dec 15, 2019
    563
    Somerset
    Hi James597,
    Do you have the tank cap in the 'unlocked' position??
    Put the key in, turn it and then remove the key, the tank cap should then spin without unscrewing and is therefore locked.
