Static wheel balance cones
Discussion in 'Triumph General Discussion' started by Smudge, Nov 16, 2015.
  1. Smudge
    Smudge New Member
    Nov 11, 2015
    manchester
    Hi Guys,
    I'm new here. Im from Manchester, UK.
    I have recently bought a static wheel balancer for mt 04 speedy triple... I have balanced the front wheel no problem... however, as the rear is a single sided arrangement the centre bore of the rear wheel is somewhere in the region of 50 - 60mm i would guess & the cones supplied with the balancer only go up to around 35m.
    My question is this: Has anyone else encountered this issue, and if so what did you use as large cones?
    Thank you.
