Trident Starting Pilot Screw Settings After Removal
Discussion in 'Thruxton, Scrambler & Trident' started by Deco, Jan 17, 2018.
  1. Deco
    Deco New Member
    Dec 31, 2017
    hi again,
    So I’ve decided that the carbs are in need of an overhaul and I’m going to replace all o rings and seals. I just wondered if any of you guys out the know what the basic set up is for the pilot screw once they been removed.
    Many thanks
    Deco
  2. t552
    t552 Senior Member
    Nov 17, 2014
    416
    Bristol UK
    2-1/4 to 2-1/2 turns from fully home. btw make are pilot jets (next to main jets) are clear. 75% of bad running on a t3 is a blocked pilot jet.
