Speed Twin - Switched Power In Headlight
Discussion in 'Technical Help' started by MotoDruid, Dec 4, 2020.
  1. MotoDruid
    MotoDruid Member
    Nov 1, 2020
    34
    Indianapolis, IN
    I'm looking at fitting some aftermarket heated grips. Ideally I'd like to use the factory installed wiring for the OS heated grips, but failing that I'd like to find a switched power source in the headlight bucket to use. The grips have a 4 amp inline fuze so it can't need more than that at peak power use.
    Anyone got any insight on which wires or connectors to use?
    - I'm an amatuer when it come to electics...
  2. t552
    t552 Senior Member
    Nov 17, 2014
    416
    Bristol UK
    Look at brake light system. Its switched live and rarely used.
  3. andyc1
    Feb 4, 2017
    2,927
    N. Ireland
    Find the part number for the triumph heated grips, should be easy, try the accessories section on their website. Then go to triumphinstructions.com and type in the part number. You'll get fitting instructions which will show you the location of the plugs.
