Speed Triple - Tool-roll Essentials.
Discussion in 'Speed Triple' started by Gled, May 7, 2018.
  1. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    Hey,
    The Triumph-supplied tool-roll that comes with the 2016 Speed Triple is *ahem* somewhat lacking.
    I had the gear linkage come undone within three months from new and could have fixed it at the side of the road with the appropriate spanner but, as I found out, the tool kit is very limited.
    So... If you were planning a trip and wanted to augment the existing tool kit with some essentials that would hopefully help you out of a predicament out on the road.
    What would be your recommendations?
    TIA
    Gled.
  2. darkman
    Small and medium adjustable spanners and tie wraps :)
  3. tcbandituk
    2,805
    Reading
    RAC card.....
  4. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    Sacrilege
    You forgot the 2lb hammer
    Gled
  5. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    Do you carry a puncture repair kit. The one with the mushrooms? I was thinking about the compressed air tyre inflators like you get for push bikes.
    Gled
  6. darkman
    Might be sacrilege but it sorted my ball unscrewing it self from the gear pedal last week :)
  7. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    Never use an adjustable on your bike ! Nasty horrible things.
    Carry a small selection of combination spanners instead.
    Get an oxford bike tool kit and add to that a 1/4” Drive ratchet. If you have a 1/4" breaker bar add that as well.
    Cable ties, duct tape are the other must have items. None of those take up much room.
    I also carry a mini compressor and puncture repaired kit if going a fair distance.
  8. Matthew Upshall
    Matthew Upshall Well-Known Member
    Apr 1, 2017
    39
    Reading
    Nothing wrong with a good quality adjustable for a portable tool kit, something like Bacho or better will last a lifetime. The jaws stay parallel so it’s just a case of making you the user knows how to adjust it correctly.
    Now if you are going to apply a serious amount of torque that’s a different matter altogether and I would suggest that you won’t be carrying out such a task at the side of the road.
    Just my two pennies worth having spent twenty odd years maintaining Boeing aircraft.
  9. steve lovatt
    Allen or hex keys.
    Wrap some insulating tape around one of the spanners - saves taking a whole roll!
  10. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    Darkman,
    That's what happened to mine. Maybe a common fault?
    Managed to limp home but damaged the threads in the alloy gear lever. Had the gear mech changed under warranty.
    Gled.
  11. darkman
    Having had Triumphs from the late 60's i always carry tie wraps n spanners to get me home, odd that we had the same prob but no surprise to me as Triumphs have always come apart on there own :)
  12. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    Great advice. Thanks Gary
  13. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    I have 3 Bachos of different sizes. For anything other than my bike they are fine. A roll of combination spanner’s up to 19mm only takes up a little more space than a couple of adjustable ones.
    Even less if you are only carrying those you need.
    Each to their own, I know which I prefer to use :)
  14. stevethegoolie
    stevethegoolie Elite Member
    Oct 16, 2014
    2,454
    East Riding of Yorkshire
    Halfords sell a mini motorcycle toolkit for £10 which looks ok for an emergency but may well need a few spanners adding to it, if only to get some purchase on the sockets via the extension provided.
    Or maybe I missed something - again!!
  15. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
    It’s similar to the Oxford one.
    I got that free for doing a quote on Carol Nash a while ago.
    Reasonable selection of sockets etc but doesn’t have a 1/4” drive ratchet so I just add my 1/4” to it.
    As a freebie can’t really complain :)
  16. youngy
    youngy Active Member
    Oct 30, 2017
    38
    Peterborough
    RAC card.
  17. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
  18. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
  19. Gled
    Gled Active Member
    Jul 25, 2017
    107
    Manchester (UK)
    The Oxford and Halfords mini toolkits look remarkably similar.
    I agree with Steve that a few additional spanners would be advantageous.
    I’m guessing these won’t fit under the seat. Can anyone confirm?
    Cheers
    Gled.
  20. GaryM
    Apr 28, 2016
    862
    Patna , Ayrshire
  21. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    I can recommend one of these compressors, but doubt you'll find room under the seat for it along with a tool roll. Fortunately 99% of the time I have the wife in tow on her Street Triple which has more space, fits under there along with the puncture repair kit (stringy type).
    It does mean I have to make sure I don't loose her in case I get a puncture though.:rolleyes::grinning:
    ...fitted a different connector so it uses the battery charge lead already fitted.
  22. Cap City Murph
    Cap City Murph Active Member
    Jul 14, 2018
    131
    Carson city nv.
