Speed Triple Rs Tyre Pressures On Supercorsa Diablo
Discussion in 'Technical Help' started by rob johnston, Aug 14, 2019.
  1. rob johnston
    rob johnston New Member
    Apr 28, 2019
    derbyshire
    Hi all can you tell me what tyre pressures people are running as 2.9 and 2.4 bar seem a bit high any help would be appreciated
  2. sam triple
    sam triple Well-Known Member
    Jul 11, 2018
    111
    hampshire
    fronts prob ok but id take 2psi out of the back ,but that's just me
  3. RSReggie
    RSReggie Active Member
    Apr 9, 2019
    114
    North West UK
    34/38 for spirited riding in the warm
    TBH standard pressure covers pillion and luggage so you can afford to lower a little unless you weigh 20 stone ...
  4. Helmut Visor
  5. Bad Billy
    I'd agree with Helmut Visor if you're riding solo & weather is warm, always check pressures cold.
    FYI - I run Super Corsa's on race bike, SC1 Front, SC2 Rear at 30/26 (Pirelli recommended) measured cold.
  6. rob johnston
    Apr 28, 2019
    derbyshire
    Thanks for that
    • Disagree Disagree x 1
  7. rob johnston
    Apr 28, 2019
    derbyshire
    Thanks for that
    thanks for that going to drop it by 2psi and see what happens then probably drop a little more depending on how she behaves
  8. rob johnston
    Apr 28, 2019
    derbyshire
    hello rs reggie I live in Derbyshire so there is quite a lot of nice roads lots of twisty back roads to fly about on and some nice long sweepers I weigh 10.5 stone, in your experience would you say 34/38 would do as I spoke to Parelli uk and they said 40 psi back and 35 psi front I still think 40 psi in the back is quite a lot I am running the supercorsa sa diablos
    thanks in advance
    Rob
  9. RSReggie
    Apr 9, 2019
    114
    North West UK
    Hi Rob I am not an expert. Make your own choice based on what you read on here and elsewhere. I can only say what I personally feel happy with . The greater loading of pillions heavy rider etc do require the higher pressures I think a lower load allows a lower pressure. Also of course if you ride hard and get the tires warm the pressure will increase do allowing a lower staring pressure (like on a track day for example). So that's a factor to consider. Maybe pirelli should give the warm pressure to go by. In the end a few psi difference isn't going to throw you off. It's what you feel comfortable with and also you can look at the tire to check it's wearing nicely .
  10. rob johnston
    Apr 28, 2019
    derbyshire
    Hi and thanks for that
  11. rob johnston
    Apr 28, 2019
    derbyshire
  12. chuk
    chuk Senior Member
    349
    neilston glasgow
    What year bike do you run these pressures,I’ve always thought 36f 42r is too much on my 2011 ride seems choppy,fine when hard on gas slower speeds not good but not unsafe.
  13. Helmut Visor
    I've run those pressures on most of my sports bikes mate 32f, 36r :cool::cool:
    If you're going to take it round a track then take a couple of psi out of each ;);)
    To my mind 36,42 is way too solid especially as it will increase as your tyre warms up :):)
  14. chuk
    chuk Senior Member
    349
    neilston glasgow
    Thanks for that bike won’t see a track just stress release runs,will deffo adjust and go out to play this weekend
  15. rob johnston
    Apr 28, 2019
    derbyshire
    Hi chuk to give you an update was out yesterday with some friends I ran 40 psi back and 35 psi front spirited riding in sport mode on a 2018 speed triple rs the bike behaved perfectly so that’s what I will be running in future
