Speed Triple Rectifier Regulator Replacement
Discussion in 'Newbies Hangout' started by Aberdeen Loon, Jul 12, 2024.
  1. Aberdeen Loon
    Aberdeen Loon New Member
    Jul 12, 2024
    Aberdeen
    Hi, looking for help folks. Anyone got a hack for replacing a rectifier/regulator on a 2011 Speed Triple please. I can’t get a spanner on the lower of the two mounting bolts. It looks like I will have to undo the r/r bracket where it mounts to the frame cross member only problem is the ABS unit and bracket obscures that route, even if I remove the ABS brackets bolts the main harness is so tight over the ABS unit I don’t see how I can move the ABS unit enough……without unplugging all the harness connectors to give me some slack. Any help most welcome, cheers.
  2. Helmut Visor
    Hi Aberdeen Loon :cool:
  3. Wessa
    Hi and welcome….,
