Speed Triple R slight oil leak
Discussion in 'Technical Help' started by Jells, May 1, 2017.
  1. Jells
    Jells New Member
    May 1, 2017
    hi there,
    Had my 2014 STR for a few weeks, I've noticed a very slight drop of oil on the ground on the left near the side stand, can't easily find where it's coming from, is this a common thing?
    Or should I take it in to have it looked at, it's very slight,
    Other than that loving the bike,
    Cheers all
  2. Sprinter
    sounds like the breather pipe ? normal if slight I think, is the oil level correct?
  3. Jells
    Jells New Member
    May 1, 2017
    Ah yes, thanks, I'll check that
  4. Red Thunder
    Red Thunder Crème de la Crème
    Dec 2, 2014
    2,034
    High Wycombe
    Could it be excess chain lube dropping from the front sprocket area?
