Looking to replace one of the front brake discs on my Speed Triple 1050 RS as only one is warped and the other is fine and hardly worn. I always thought they were Brembo but they appear to be Sunstar which is stamped on the carrier. So to make sure I get oem Sunstar, to match the other, it looks like I will have to buy off a Triumph dealer.
I have a little warping on mine, not sure if it’s one or two discs. Will live with it at present as it’s not huge . Feckin annoying though..!
Trouble is it might fail the MOT. Got an advisory this time but if I do nothing it will probably fail next time.
I've got 2 discs from Brembo importers that I had fitted to my 1200 Thruxton. might be the same fitting for a Speed Triple if you are interested, less than 1,000 miles on them.
