Speed Triple 94r Starter Solenoid
Discussion in 'Speed Triple' started by Bolosun, Mar 16, 2022.
  1. Bolosun
    Bolosun Well-Known Member
    Aug 25, 2020
    231
    Crewe/Cheshire
    Where is it? I have the Haynes manual and the description and picture of where it is very vague.
  2. joe mc donald
    #2 joe mc donald, Mar 16, 2022
    Bolosun
    Just follow the wires from the starter motor and you will locate it.
  3. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    If only it was that easy :(
  4. joe mc donald
    Bolosun.
    Sorry.
  5. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    I'll have another try tomorrow and see if I can follow the cables. When I find I'll report back for anyone else who needs to know.
  6. joe mc donald
    Bolosun.
    Fantastic idea. Hope all goes well for you.
  7. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    Found it! :blush:
    It is fixed to the RHS frame tube underneath the main wiring loom as it runs from under the airbox towards the ABS module.
  8. capt
    capt Elite Member
    May 8, 2016
    3,050
    western Australia
    Why were you looking for it
  9. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    I have the infamous "wont start issue." So have cleaned the starter, kill and clutch switch. Cleaned and checked the earths in the starter motor. Someone else said check the starter solenoid. Which was why I was looking for it. The 2 wires that go into the top of the solenoid were looses and mucky. So cleaned them up and regreased.
  10. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    Don't forget the side-stand switch. :)
    (There's also a relay that feeds the solenoid)
  11. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    Side stand switch doesn't stop the bike from starting, unless it is in gear also. Will have a check of the relay, may buy another one and swap if it does it again.
  12. Col_C
    Aug 5, 2015
    1,431
    Any joy yet?
  13. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    The bike starts as it should. The problem I have is the issue is very intermittent. So time will tell if I have fixed it or not.
  14. Col_C
    Aug 5, 2015
    1,431
    Ah, didn't realise, intermittent's are a bugger to track down.
    Have you checked your battery is in tiptop condition, you may know that the ecu is designed to disable starting on a weak battery. I replaced mine last year as I was getting very occasional non starts (often seemed to be at a certain petrol station - still not sure if there was any relevance). I bought Motobatt AGM and would recommend, not had any problems since.
  15. Bolosun
    Aug 25, 2020
    231
    Crewe/Cheshire
    Fitted a new battery this month. The one on it was the original when the bike was new, so 6 years old. :eek:
  16. Col_C
    Aug 5, 2015
    1,431
    Mine is a 94R also so must be about the same age (65 plate), 6 yrs must be about the limit. SWMBO's Street Triple must be imminent. :rolleyes:
