Speed Triple 2016 - Supercorsa Tyres Pressure
Discussion in 'Technical Help' started by Blueskip, Nov 25, 2017.
  1. Blueskip
    Blueskip Member
    Nov 19, 2017
    Paris
    Hi everyone,
    I ride a 2016' S3R fitted with the OEM Supercorsas V2.
    According to the Speed triple manual, the recommended tyre pressures are 2.3 on the front and 2.9 on the rear, for road use. This is what I use and so far so good for what I do.
    Now, after looking at Pirelli's website, the recommended pressures are somewhat lower for the front (2.0-2.2) , but way lower for the rear (1.6-1.8) !!
    https://www.pirelli.com/tyres/en-gb.../sheet/diablo-supercorsa-sp#/technical-advice
    It looks to me that the pressures recommended by triumph are more relevant for a road use where tyres will hardly warm up, and to prevent a ridiculously quick wear of these £££ supercorsas.
    Is anyone able to explain why there is so much difference for the rear pressure?
    thanks!
    Rémi
  2. Oldyam
    Oldyam Grumpy Old Git
    May 14, 2017
    610
    ireland
    The data sheet you have referenced looks to be for Track use, where the application is more severe, as I don't know many people who use tyre warmers on their road bikes
  3. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    Track pressures are too extreme for road use, but many Speed3 riders tend to drop pressures a tad. I'm running Metzeler M7RR at 32psi front / 36 rear.
    Personally wasn't a fan of Supercorsa's when cold or wet (plus wear pretty quick).
  4. Sprinter
    Be aware lower pressures require a little longer warm up.
  5. Yorkshireman
    How do you figure that? Running them a bit softer results in a bit more flex of the carcass making them warm up faster. As an example have you ever felt an under inflated tyre on your car, it will be much warmer than any others that are at the “correct” higher pressure.
  6. tcbandituk
    2,805
    Reading
    On a cold wet day like today, the pressures ares irrelevant as SuperCorsas will never warm up, The traction control system will be working overtime though ;)
  7. Blueskip
    Blueskip Member
    Nov 19, 2017
    Paris
    That's quite true, I experienced a 3 seconds long intervention of the traction control while rolling on the throttle too enthusiastically the other day. I was on the motorway under the rain. I was truly amazed how smoothly the electronics kicked in, you can barely feel any wobble when it switches on and off. It was much more blunt with my previous bike (bmw)
  8. Sprinter
    Warm up from rest to working pressure, not work at a higher temp
