Spacers For Front Wheel
Discussion in 'Speed Triple' started by Dougie D, May 8, 2018.
  1. Dougie D
    i've just removed my front wheel as i'm needing to replace the tyre,i've got the spacers mixed up,i don't think it will matter which side i put them in as they look identical or even which way round i put them.it says in the manual to note which side they came off..but i forgot:confused: does it make a difference?
  2. Oldyam
    Oldyam Grumpy Old Git
    May 14, 2017
    610
    ireland
  3. Dougie D
    cheers,both are the same,i'm guesing it makes no difference which way you put them in either,but i'll check DDs suggestion and see if i can see any marks
  4. Col_C
    Col_C I can't re...Member
    Aug 5, 2015
    1,431
    You'll probably see a line where the seals rub.
  5. Dougie D
    couldn't see any marks on the spacers, i think I've put them in the way they came out, but i don't think it would matter as they are identical
  6. Dougie D
    looking at the Haynes manual it says the front axle should be tightened to 65nm but for the previous vin numbers it says 95nm why would there be such a difference?..just wondering in case they should both be 95nm and it's a misprint
  7. Sprinter
    My Sprint is 61Nm, I would go with the manual, unless someone has a workshop manual on line.
    I have tightened mine to 61Nm with no problem and 61Nm seams about right the only things I have over 100 are the front sprocket and the rear wheel. My manual says the same IE Speed after vin 461332 65Nm.
  8. Dougie D
    you probably got the same manual as me 05 to 13 although mines a 14 but it's the same as the 13..should be ok with 65Nm
  9. Col_C
    Aug 5, 2015
    1,431
    I have a copy of the Triumph manual for Speed Triple, 65Nm is correct for the axle, however there is a difference for the pinch bolts between standard an R version (with Ohlins fork) - 22Nm for standard, - 19Nm for the R.
    Be wary of over-tightening the pinch bolts, I had the misfortune of spending a few years with a Ducati and there are numerous tales of cracked fork bottom castings due to this.
