Is there a circuit or line I can tap to use as a signal when the engine is running (as opposed to just having key in the on position)? I am installing some heated grips, and prefer to have them on only when the engine is actually running. If not I'll use something that is on when the bike is on. I plan to use the signal to operate a mosfet switch or relay for heated grips I will be installing.
