Satnav Power Via Diagnostics
Discussion in 'Technical Help' started by Stuart1969, Feb 18, 2019.
  1. Stuart1969
    Stuart1969 New Member
    Jan 24, 2019
    Angus
    HI I was messing about yesterday under the seat of my 2018 Tiger 1200 xrt and found that I could power my satnav with the usb under the rear seat,i assume this is the diagnostics plug,has anybody tried this or is this a no no.
  2. crispey
    Diagnostic plug is usually a multipin affair.
    If the usb plug is powered go for it but if it still has power when ignition is switched off make sure you disconnect it as the satnav mounts can still draw power even if the satnavs removed
  3. Stuart1969
    Jan 24, 2019
    Angus
    I did check and it only has power if the ignition is switched on,so happy days
  4. tcbandituk
    2,807
    Reading
    Be aware that if you're using the USB power lead to power a GPS, the connection won't be waterproof at either end.
  5. Stuart1969
    Jan 24, 2019
    Angus
    cheers for that
