Rear Suspension Speed Twin
Discussion in 'Technical Help' started by Jasper123, Jul 10, 2019.
  1. Jasper123
    Jasper123 New Member
    Jul 10, 2019
    Hi all,
    I have a Speed Twin and want to replace the rear suspension and lower the rear a little bit.
    I searched on this forum and found for example the YSS shocks, and also the TEC shocks. What are the experiences with this shocks? Do you have photo's of it on a Speed Twin?
    Does anyone know the offical measurements of the original rear shocks?
    For example this website says it is 390mm: https://www.britishlegends.fr/en/yss-dampers-speed-twin.html?id=191893014 . But when i'm measuring, it is between 385/388.
    Thanks a lot!
  2. Jasper123
    Jul 10, 2019
    Thanks for your reply. I've mailed the website britishlegends.fr and they think these are the right measurements, the same as Thruxton. But I've heard the Thruxton shocks are longer, so it is a gamble.... On the YSS website the Speed Twin measurements are not available on this moment :-(.
  3. Vulpes
    Hi and welcome. I think @darkman on here said they were 385mm?
  4. darkman
    Just as a note the top eye bush mount hole is 16mm that slides over pin on frame and lower is 10mm bolt thats goes through the shock bush, i used a 16 x 20 x 10mm hole spacer in the lowers as they came with 16mm top n bottom.
  5. darkman
    Another note, i used RZ362-370TRL-02-X YSS rear shocks with 46 20 30 240 springs for my weight, these are + or - 10mm and they came with inserts for 14mm and by removing the top insert it gives you 16mm for top fitting and you use a 20 x 16 x 10mm hole spacer in the bottom.
  6. t552
    t552 Senior Member
    Nov 17, 2014
    416
    Bristol UK
    YSS are adjustable shock length, usually +-5mm
