Plate Gasket 955i .
Discussion in 'Technical Help' started by Arnie williams, Apr 21, 2021.
  1. Arnie williams
    Arnie williams Well-Known Member
    Sep 1, 2018
    26
    Airdrie
    Hello it's me again can anyone give me some advice I have got an undamaged tank and I am coating inside with Caswells and then a respray (not cheap so far) When I put the pump and fuel level sensors off the old tank it states replace both gaskets about £60. can I use old gaskets with Hylomar blue gasket seal and if I put new gaskets on do I still use this.
  2. Arnie williams
    Sep 1, 2018
    26
    Airdrie
  3. Iceman
    Iceman Crème de la Crème
    Apr 19, 2020
    2,339
    Lancashire
    Hi Arnie, I would not recommend using Hylomar on gaskets for the fuel pump and level sensor, also I would strongly advise using new gaskets, it is false economy attempting to re use old gaskets, you are spending a lot of money for the work on your tank, don't risk it by shortcuts. Try Sprint Manufacturing, they have quality products at a more reasonable cost that OEM parts.
  4. Arnie williams
    Sep 1, 2018
    26
    Airdrie
    Thanks for your response as I am spending over £400 on second hand tank.Cadwells treatment and spray job and graphics. I think I will take your advice. cheers.
